removing and replacing headliner fabric?
Old Mar 23, 2009 | 12:51 AM
96civicexrican's Avatar
Default removing and replacing headliner fabric?
I know I saw this in here somewhere awhile back and now I cannot find it. Can anyone please post a link to this for me. I need step by step instructions on how to remove the headliner and sunroof cover in order to replace the fabric that is on them. Any help would be great.
PS- I also look under the DIY section and have found nothing.
Thanks,
Nick
Old Mar 23, 2009 | 01:52 AM
Default Re: removing and replacing headliner fabric?
what?
Old Mar 23, 2009 | 06:07 AM
mrlegoman's Avatar
I don't know the post your talking about, but it's not that difficult a process. You just need to be careful when pulling off the trim to not break the plastic tabs holding the metal clips in. I bought some headliner material from JCWhitney and some spray-on adhesive and it came out looking perfect.
Old Mar 23, 2009 | 08:56 AM
Anyone have detailed instructions on how to do this?
Old Mar 23, 2009 | 09:04 AM
IP RACING's Avatar
i would like to see a write up too before I dive into a new headliner
Old Mar 23, 2009 | 09:54 AM
01d17's Avatar
it is actually very easy. all you need to do is pull out the lights in the roof, the sun visors and easily pull the head liner down. It's held in with clips like most panels and you just need to pop off all the clips and then slide it forward to unlock it out of the final clips in the middle.
Old Mar 23, 2009 | 10:56 PM
anyone?
Old Mar 25, 2009 | 04:10 PM
I guess not. Thanks anyways guys/gals
Old Mar 25, 2009 | 04:17 PM
mrlegoman's Avatar
You've pretty much already been given the answer. It's such an easy procedure that your not going to find a write up pr pics on it.
01d17 pretty much gave you all the info you need to know. Just take it slow and easy.
Old Apr 16, 2009 | 08:07 PM
Js-TM's Avatar
http://www.team-integra.net/sections...ArticleID=1147
Old Apr 16, 2009 | 08:24 PM
Frost7177's Avatar
its easy take off all the necessary stuff off the head liner peel the old headliner off get some headliner spray from autozone cut and trim also when i did mine i made sure the headliner wrapped around to the other sideand cut like and 1 away from the edges and let it on the other side and sprayed the headliner stuff again.
Sweetsystem
Sep 12, 2008 07:45 AM
KILLAB17VTEC
Jun 18, 2008 04:39 PM
Byaaah!
May 27, 2007 09:22 AM
00gs-r
Dec 12, 2006 04:16 PM
