y8 b7 mini my swap what dizzy do i use?
Old Mar 22, 2009 | 10:11 PM
xwhitchx's Avatar
Default y8 b7 mini my swap what dizzy do i use?
y8 b7 mini my swap what dizzy do i use? im putting it in to a eg obd1.
Old Mar 23, 2009 | 03:27 AM
94EG8's Avatar
Seagull Management
Default Re: y8 b7 mini my swap what dizzy do i use?
D15B7, bolts up to a Y7, Y8 head, and obviously plugs in.
Old Mar 23, 2009 | 04:19 AM
panswed's Avatar
New User
I am using the y8 head with the z1 block ( obd1 eg ) can I use my z1 dizzy?
Old Mar 23, 2009 | 08:28 AM
CivicSpoon's Avatar
Nope, the Z1 is completely different, as is the Z6.
Old Mar 23, 2009 | 01:59 PM
94EG8's Avatar
Seagull Management
Correct
Just so you're aware though you're dropping your compression down quite low using that Y8 head on a Z1 block, might be ok if you're planning to boost, but I wouldn't do it if you plan to stay naturally aspirated.
R3X5150
14
May 14, 2013 01:12 AM
superhatchbackbros
Sep 30, 2010 05:59 AM
99_itr
13
Dec 24, 2007 10:24 PM
audiimportech
Sep 3, 2006 05:19 PM
project dc2
Dec 19, 2002 10:42 PM
