adding 40 hp with boltons???
Old Mar 22, 2009 | 07:52 PM
jr408's Avatar
Default adding 40 hp with boltons???
will this set up add 40 more hp to my integra or how much more hp will that add to my car...im just starting to build my motor
skunk2 intake manifold
OBX HIGH FLOW cat
Integra Fuel Line kit
OBX Fuel Filter
AEM Fuel Rail Kit
GODSPEED 94-01 INTEGRA DC2 B18 RACING ALUMINUM RADIATOR
OBX Radiator Hose 94-01 Integra LS RS GS Siicone Black
2 12" UNIVERSAL SLIM ELECTRIC RADIATOR FAN RSX TL INTEGRA
OBX Throttle Body 94-01 Integra DC2 GSR LS Type R 70mm
MSD 94-01 Acura Integra 6A Ignition External Coil Kit
ACURA INTEGRA GSR 10.2MM RACING SPARK PLUG WIRES BLACK.
Old Mar 22, 2009 | 07:57 PM
ruffrhyder's Avatar
Default Re: adding 40 hp with boltons???
OBX HIGH FLOW cat
OBX Fuel Filter
AEM Fuel Rail Kit
Most of these 'mods' are useless. Ditch the obx fuel filter, get a regular oem or aftermarket nippon filter from www.rockauto.com for like $15. Ditch the aem fuel rail, stock if fine for almost any all motor build. Oem radiator is fine unless yours is already cracked. OBX rad. hoses don't add any power, neither do the slim fans. That 70mm throttle body is overkill and will most likely cause you to loose power. OEM ignition coil is fine for all motor builds, so are the stock ngk wires.
Old Mar 22, 2009 | 08:01 PM
lexan2.2sedan's Avatar
you're looking at roughly 4-6 hp with those mods.
stop. no. & don't.
Old Mar 22, 2009 | 08:12 PM
domokun!!!'s Avatar
where is the common sense at?
Old Mar 22, 2009 | 08:27 PM
BMo Tuning's Avatar
STAR
only if you **** in the oil
Old Mar 22, 2009 | 08:42 PM
bossm's Avatar
no not from intake,im,tb you are gonna gain 40hp you couldnt even do that to a k series lol
Old Mar 22, 2009 | 08:44 PM
bossm's Avatar
stop. no. & don't.
dont forget with the obx radiator it will be the other 34-36hp that your guesstimation will add
btw we didnt need to know the color of the spark plug wires lol
Old Mar 22, 2009 | 08:45 PM
Teamdiesel's Avatar
OBX HIGH FLOW cat
OBX Fuel Filter
AEM Fuel Rail Kit
You are joking....right?
Old Mar 22, 2009 | 11:42 PM
racebum's Avatar
you can almost buy a used jackson supercharger for what all that costs. it will add 40hp. what you listed is more like 4hp
Old Mar 23, 2009 | 01:44 AM
EcHoB18C1's Avatar
=/ what are u thinking..
Old Mar 23, 2009 | 06:16 AM
Rickytec_b16's Avatar
ur living a dream lol
Old Mar 23, 2009 | 07:24 AM
tealchief's Avatar
get some spray
Old Mar 23, 2009 | 07:37 AM
DC_Legacy's Avatar
Originally Posted by tealchief
get some spray
x2
Old Mar 23, 2009 | 07:38 AM
alterdcreations's Avatar
boost
Old Mar 23, 2009 | 07:43 AM
haas480's Avatar
def booooooooost.
and you didn't even specifiy your motor?
but maybe a gsr since you're buyin those trick plug wires made specifically for only race gsr's.
Old Mar 23, 2009 | 07:45 AM
00b20vtecoupe's Avatar
this made me laughh....
Old Mar 23, 2009 | 08:03 AM
mikesrex's Avatar
40 WHP? not even close. This reminds me of another guy...
apparently there is a guy that thinks his Hytech Header gave him 50 WHP
his logic:
1. motor made 199 on a dynojet with OEM header
2. same motor made 220 WHP on a mustang dyno with Hytech, so add 15% to this number to achieve estimated 250+ WHP estimated value on a dynojet.
theoretical outcome: "Hytech Header gave me 50 WHP!!!!"
Old Mar 23, 2009 | 08:23 AM
fergy016's Avatar
Bolt on a Jackson Racing Supercharger. It costs $2465.00 new so you can find one for 1500 or so used if you look around.
There is also Vorech supercharger kit. I just searched google shopping and it is $3269.00
Old Mar 23, 2009 | 08:24 AM
jr408's Avatar
good thing i asked coz it didnt seem real to me either.i was aiming hckru and hes also on here...thx guys...seems like he was being for real..he even gave me a whole list worth almost 7-8 g to get 225 hp.ill give you guys the list.you think all of these will give u 225 hp..:::
JDM b16 P30 pistons w/rings 81mm $320 Shipped
OEM Honda engine bearrings $250 Shipped
crower cams $340 Shipped
cam gears $120 Shipped
valves $300 Shipped.
valve springs/retainers $350 Shipped
rocker arms $160 shipped
cam seal $20 Shipped
1st stage port and polish $500
micro polish and balace crank $150
Block hone/cleanning job $220
oil pump $115 Shipped
altenator $140 Shipped
timing/ac/ps belts $150 Shipped
DC headers $310 Shipped
apexi WS 2 exhaust $450
skunk 2 intake manifold $260 Shipped
tensioner $65 Shipped
thermostat $25 Shipped
dizzy $200 Shipped
spark plugs/cables $40 Shipped
injectors $100 Shipped
fuel rail $90 Shipped
fuel line $70 Shipped
fuel filter $65 Shipped
oil filter $30
pulley kit $100 Shipped
B16 tranny $700 Shipped
O2 sensors $110 Shipped
ARP studs/bolts $260 Shipped
OEM HONDA head gasket $90
Fly Wheel/clutch $450 Shipped
shift linkage $150 Shipped
throttle body $190 Shipped
oil pan $200 Shipped
starter $100 Shipped
radiator/hoses $ 220 Shipped
i-beam rods $260 Shipped
hasport motor mounts $250
Old Mar 23, 2009 | 08:34 AM
bossm's Avatar
is this a ls............anyway i still dont think you will hit 225whp with that setup
why not throw a vtec head on that
Old Mar 23, 2009 | 08:47 AM
1turbodeg's Avatar
get a b16 head with gsr cams port and polish it
supertech valve train
obx im port it
tune it and youll see a really good number pop up.....
Old Mar 23, 2009 | 09:04 AM
mar778c's Avatar
Community Builder
Community Influencer
Lol.
Old Mar 23, 2009 | 09:16 AM
kgibson16's Avatar
secret of the pro's, keep this on the dl if u know what i mean.lol
Need more power?! The Super e-RAM electric supercharger uses two e-RAM units stacked as a dual-stage compressor to deliver an average of 8.5% horsepower gain on virtually ANY internal combustion engine.
1.7 PSI NET BOOST (measured on the intake at wide-open throttle)
Up to 27 more horsepower GUARANTEED!
(see Guarantee/Warranty page for details)
Safely draws over 1666 WATTS from the battery when activated at full-throttle!
Together, both powerful e-RAM units draw over 124 AMPS!
Total unrestricted air-flow is 800 CFM when stacked as shown, or 1600 CFM when mounted in parallel to get 5% HP gain on engines larger than 5.0L or over 300HP.
8.5% more horsepower through the entire RPM range!
Old Mar 23, 2009 | 09:24 AM
vetkid89's Avatar
ummm wow.
Old Mar 23, 2009 | 09:27 AM
DC_Legacy's Avatar
POWER!!! LOL....
