95 integra gsr problem
Old Mar 22, 2009 | 06:12 PM
210southstar's Avatar
Default 95 integra gsr problem
Seems to miss when vtec kicks in at bout 4500 rpms till about 5000 rpms then gains power like regular. Only happens when car is cold after about 10 minutes of driving it doesnt happen?
Old Mar 22, 2009 | 06:57 PM
Crx_b16's Avatar
Default Re: 95 integra gsr problem
LoL thats because your vtec wont kick in when your car is cold, at least it shouldnt unless its being by passed by a chipped ecu.
Old Mar 22, 2009 | 08:58 PM
ummmmmm it just started doing it recently. Never had this problem before soooooo vtec not workin when cold?
Old Mar 22, 2009 | 11:09 PM
KPDSM's Avatar
well vtec shouldnt engage until your car is warm. unless neptune or something of the sort tells your ecu to ignore thermostat temp and engage vtec neway.
Old Mar 23, 2009 | 05:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
um stop getting on it with the engine cold. Problem solved. Are you TRYING to destroy your engine? 80% of engine wear occurs at startup, when the oil is cold and thick. VTEC requires oil pressure to operate and to force the oil through the passages to lock the rocker arms together. When the car is cold, that doesn't really work as well.
Old Mar 23, 2009 | 05:27 AM
Hmmmm was unaware of that kinda new to tha car had all mustangs before Well thank everyone
Old Mar 23, 2009 | 09:06 AM
BlurpleDC2's Avatar
Not a big deal I did the same thing when I first got my gsr. I would go to step on it and the car would bog out and nearly die past 5k rpm. What you gotta do is warm the car up and drive it around for 5 mins then you are allowed to rev the ever loving **** out of it from then on.
Old Mar 23, 2009 | 09:19 AM
Community Builder
uhhh not stomping on it when cold pretty much goes for all cars. Claiming American is not excuse.
Old Mar 23, 2009 | 07:33 PM
JUICED COUPE's Avatar
lol
migs
Mar 1, 2007 11:01 AM
bazooka
Sep 5, 2006 04:13 AM
95dhocinteg
Oct 7, 2005 05:34 PM
srehmat02
Sep 17, 2004 02:24 AM
