ECU upgrade for JDM Spec Prelude Type S.
Old Mar 22, 2009 | 05:44 PM
nemoyan's Avatar
Default ECU upgrade for JDM Spec Prelude Type S.
Hi guys can u guys give me recommendations for my JDM SPEC Prelude Type S? Which ECU upgrade does a plu and play harness for my car?
E-Mange? AEM EMS? AEM IC/FC?
I really do not know which and what brand will fit my car plug and play wise...
Old Mar 22, 2009 | 06:35 PM
Kronn 98SH's Avatar
Default Re: ECU upgrade for JDM Spec Prelude Type S.
The AEM F/IC is suppose to have an optional PnP harness coming soon. I don't know if it's been released yet or not. I know you can get a VAFC with a PnP harness (cuz I have one).
Old Mar 22, 2009 | 07:03 PM
nemoyan's Avatar
I am looking at a ECU with more resolution and tuning capibilites.
The VAFC does not have ignition timing tuning capibilites right?
Old Mar 22, 2009 | 07:14 PM
Kronn 98SH's Avatar
That is correct.
Old Mar 22, 2009 | 07:22 PM
vinuneuro's Avatar
AEM EMS is a standalone. You have to keep the stock ecu to retain ATTS. Greddy Emanage Ultimate will be the best performing given the constraints.
Have a look through this:
http://www.s2ki.com/forums/index.php...ic=408667&st=0
Old Mar 22, 2009 | 07:24 PM
gstrudler's Avatar
EDIT: bah! vin beat me to it again.
Don't forget with the ATTS (assuming you kept it), you probably won't be able to do anything standalone, unless you can run parallel ECU's. eManage Ultimate is probably the best piggyback you can do, but I don't believe it does ignition timing either. If you figure something else out, I'd like to know...
Old Mar 22, 2009 | 07:58 PM
nemoyan's Avatar
Does the E-manage Ultimate come with PnP harness??
Can u guys give me links on where to enquire and buy the E-mange?
Old Mar 22, 2009 | 07:59 PM
Kronn 98SH's Avatar
www.google.com
www.ebay.com
www.craigslist.com
Old Mar 22, 2009 | 08:00 PM
Kronn 98SH's Avatar
Why do you recommend Greddy eManage over AEM F/IC, especially considering the F/IC has timing control.
Old Mar 22, 2009 | 08:11 PM
nemoyan's Avatar
Hey Bro I check with AEm... they do not have a plug and play harness for my car. U know where i can get it?
Old Mar 22, 2009 | 11:26 PM
Kronn 98SH's Avatar
No idea.
Old Mar 23, 2009 | 12:41 AM
gstrudler's Avatar
Sorry, wasn't familiar with the F/IC from AEM; looks like a decent box too. And I was wrong, the Ultimate does have support for ignition control. If you can't tell, I don't have a lot of experience with engine management yet :/ The AEM has slightly better resolution (21x17), although I thought the Ultimate had better res over the standard eManage (16x16), but I could be wrong again. The Ultimate does look like it has quite a few correction and modifier maps, however, that the AEM doesn't appear to have.
nemoyan, check out Boomslang for PnP harnesses: www.boomslang.us, they carry them for most piggyback and standalone controllers (including the AEM F/IC and the eManage/Ultimate)
Old Mar 23, 2009 | 01:08 AM
vinuneuro's Avatar
The F/IC has a major drawback. It can't advance ignition. Emanage Ultimate is as good as it gets for a piggyback. Definitely don't buy new; you can find them used or nearly new at tremendous discounts.
Old Mar 23, 2009 | 02:53 AM
Kronn 98SH's Avatar
So the AEM F/IC can only retard ignition timing?
Old Mar 23, 2009 | 05:27 PM
nemoyan's Avatar
Hey guys i notice u guys dun talk much about Dastek Unichip Q? Is it a good chip upgrade?
Old Mar 25, 2009 | 05:49 PM
nemoyan's Avatar
HI Guys, I have decided on getting the E-manage Ultimate. Hopefully it works out well. Currently running on stock JDM Spec prelude Type S. With CAI and Freeflow muffler..... will see what i can get out of the car with ECU tuning b4 deciding on cams upgrade...
Hope everything goes well.
Old Mar 25, 2009 | 07:17 PM
gstrudler's Avatar
i'd be interested in seeing results of tuning on a mostly stock motor. before/after dyno would be great.
Old Mar 25, 2009 | 07:58 PM
nemoyan's Avatar
i will try my best to do a posting and write up about it.
Old Mar 26, 2009 | 11:05 AM
RattyMcClelland's Avatar
Yer this will be interesting to see as the Type S uses a tuned ECU of the H22a8 as they are practically the same engine minus the 17bhp difference. So the JDM ECU is already very well tuned, lets see how far it can be taken so i will get one.
Old Mar 26, 2009 | 04:48 PM
nemoyan's Avatar
Actually... i think due to the age of the car I find that my car is running too rich... one of the things i will look into while tuning.... currently shifting gears in the high rpm to lean out the fueling..... I also agree that JDM ECUs are well tuned.. and hoping to bring it one step further... lets hope I am able to do so.
Thanks Guys! The report will not be in so early cause I need to change the engine mount on my car and gear box seals first. After that I will concentrate on tuning the car . And maybe somewhere down the road i will think of doing cams and pistons.(if budget allows... heehee)
Old Mar 26, 2009 | 04:58 PM
nemoyan's Avatar
A quick run down of what i have did over the past 3 mths when i bought this 2nd hand Beauty!!
Original Parts that i changed:
Timing Belt
Alternator and Steering Belt
Water Pump and Bearings
Top gasket seal
Oil Pump Seal
Cam Seals
Next Original Part change(will be done next week)
Engine mount (All FOur)
EGR valve cleaning plus gasket change
IAVC valve change
Clutch and release bearing
Gear Seals
Current aftermarket mods:
CAI
Wheel Enkei RC5 17inch
Free flow muffler
Tanabe front and rear under braces
Rear Strut Tower (Ebay Brand)
Next Aftermarket Mods
Lightened Flywheel by Competition Clutch (14lbs)
E-Manage Ultimate plus tuning
Old Apr 28, 2009 | 06:12 PM
nemoyan's Avatar
Hi Bros!!! I done my EMU already...
Did butt tuning so no dyno graph to show currently...
But sure did not regret.... was able to tune it to give a smoother and fast rev range.... i love the way my car drives now... its almost stock.
But i got one question. Do u guys know my car stock ignition timing...cause i think the ex owner played around with it b4... i want to move it back to stock and tune it from there.
Smidge
Dec 20, 2015 03:03 PM
swappedcivic
Nov 14, 2005 01:44 AM
firstclassjdm
Jan 31, 2005 03:19 PM
- Sim -
Sep 5, 2004 05:29 AM
Cowboy
Nov 18, 2003 11:59 AM
