Bosch saturated injectors
set crank injector time table to around 150-180 and the settings to input for the injector dead time can be found under SETUP>Injectors>Primary>Batt Offest Table. there you can input the values. it only give you even battery voltage but aem can interpolate the odd batt voltage values
