How do you paint a custom valve cover? (Not just powdercoating it)
Old Mar 22, 2009 | 02:03 PM
F20hachi's Avatar
Default How do you paint a custom valve cover? (Not just powdercoating it)
Sorry no, im not talking about your regular powdercoating. Im talking about custom characters/artwork on a valve cover. I need to know what kind of primer and paint to use/where to get it. Also, what type of clear to use to protect the custom work. All help is appreciated . Ive been checking threads, and all ive seen are powdercoated VC's
Old Mar 22, 2009 | 03:06 PM
HighRevn's Avatar
Default Re: How do you paint a custom valve cover? (Not just powdercoating it)
Let me first ask you, will you be painting the valve cover and have you ever painted before.
The reason I ask this, if you dont have alot of experience painting and are looking do something custom(other than a solid color) it probably would be more cost effective and easier to bring it to a local painter or shop and tell them what you want.
Old Mar 22, 2009 | 03:28 PM
2000r#0283's Avatar
My VC was stripped to bare metal, then was sanded smooth. Sprayed a epoxy sealer down then a high build primer. Sanded down with 600 grit and then the basecoat was sprayed. Then 3 coats of automotive clear.
Old Mar 22, 2009 | 07:30 PM
F20hachi's Avatar
thx for the responses, im having a friend of mine who's a real good artist do the custom work for me. He's only done artwork on paper and walls before. All we have to find out is what high temperature primer/paint/clear to use then we should be all ready to go.
Old Mar 22, 2009 | 07:41 PM
blue2000em1's Avatar
Highrevn is very correct on this keep in mind what paint you're going to use??If it's not a polyester basecoat,then good luck throwing frisk it paper on to do your sketching.Paints like ppg,Dupont require you to throw your first coat of base put a intercoat clear let it "dry" water sand it start your art work"and then clear.Paints like Diamont,Metalux,Spies hecker,Sikkens,Debeers don't require this method but be work that the clear must be thrown on before 24 hours or you will've serious adhesion problems.And your artwork will go to waste.
xXViperXx
Paint and Body
Sep 28, 2009 10:09 AM
felixjr18
Paint and Body
Apr 29, 2009 11:07 AM
hi mom
Mar 8, 2003 01:05 PM
ih8danoles
Oct 27, 2002 01:22 PM
