Can you align the tps with s300?
Old Mar 22, 2009 | 10:56 AM
TwoKSiR's Avatar
Default Can you align the tps with s300?
I'm trying to set my roommates TPS and I can't find my multimeter. So I figured I can do it with the s300 but it always says -26%. Even when imove the tps. Is there away I can do it?
Old Mar 22, 2009 | 12:44 PM
mtber's Avatar
Default Re: Can you align the tps with s300?
Yes, you should be able to.
I would suggest using a multi-meter to ensure everything is matching up etc.
Old Mar 22, 2009 | 04:34 PM
xenocron's Avatar
-26% seem way out...
normally the most I think you can see is -12% and thats with the TPS completely off.
Take the TPS off of the TB still plugged into the connector, turn the car to the ON position (not running) and start datalogging...see if by manually turning the TPS with your hand you can get SManager to show you the full range of motion (and then some).
Old Mar 23, 2009 | 03:37 AM
boosted k20's Avatar
some software wont show correct TPS settings with ignition on and car off. u need to have the car running in order to see the correct TPS %.
Old Mar 23, 2009 | 06:24 AM
mtber's Avatar
Incorrect. With the ignition on & the engine off you can calibrate the tps.
unspankable
Aug 13, 2014 05:04 PM
b18cEK
Apr 4, 2006 04:09 PM
CRX A4
Jun 14, 2003 09:43 AM
UrbanCricket
Mar 2, 2003 08:18 PM
