acuraautomotiveparts.org
Old Mar 21, 2009 | 10:04 PM
Adankid's Avatar
Default acuraautomotiveparts.org
Okay, so I've been searching on this website, and I'm having a hard time finding these parts I need,
vehicle: 1994 Integra gsr
-vtec solenoid gasket
-distributor o-ring
If someone would please pull up the parts number I would highly appreciate it.
And also, where can I get some hondabond online?
thanks in advance.
Old Mar 21, 2009 | 10:24 PM
EX PLCIT's Avatar
Default Re: acuraautomotiveparts.org
Another option for you would be http://inlinefour.com/genhonpar.html which carries all the things you mentioned.
Old Mar 21, 2009 | 10:32 PM
racebum's Avatar
i would go to the dealer, both parts are cheap enough that the mail savings will be ate in shipping.
Old Mar 21, 2009 | 10:53 PM
Adankid's Avatar
this is what i ended up doing.
I also picked up another hamp oil filter, I'll be changing out my oil soon.
Old Mar 22, 2009 | 04:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Not sure why you're having a hard time, I found these within a matter of seconds:
#7 30110-PA1-732 O-RING (26.4X3.1) (TEC) $1.37
http://www.acuraautomotiveparts.org/...s=&view=normal
#12 15825-P08-005 FILTER ASSY., SPOOL VALVE $12.89
*edit dang InlineFour is a major ripoff on some of those factory Honda parts. $5 for 5 oil drain bolt crush washers?! I usually buy a string of 20 washers for $5 from Carland Acura when I'm buying other parts, too.
Old Mar 22, 2009 | 10:37 PM
jdmef9gsr's Avatar
go to hondapartsunlimited.com
Old Mar 23, 2009 | 05:12 AM
Community Builder
Carland Acura is cheaper, but you may want to use whoever is closer to you.
Showcase Honda (hondapartsunlimited.com) is out of Arizona.
Carland Acura (acuraautomotiveparts.org) is out of Georgia, so for me they're cheaper and regular shipping only takes about 2 days.
Old Mar 23, 2009 | 06:11 AM
nsxtasy's Avatar
H-T Order of Merit
Delray Acura (acuraoemparts.com) is in Florida, and is another choice.
go-part
Dec 15, 2012 02:10 PM
rash
Honda S2000
Jul 12, 2010 12:52 PM
Lmgrcivic
Dec 14, 2009 05:42 PM
SpeedMachine
Apr 13, 2005 05:38 PM
