90 civic sedan question???????
ok so its stock d15 5spd dual point,had a burnt valve so i replaced head and put a different intake on today and now car will turn over but no start.the firing order,compression,spark,fuel,and timing are all perfect just no start.it ran before just had a miss so im all out of ideas.any help would be great and thaks in advance.
different intake meaning what? did you do a dpfi to a mpfi? cause it sounds like that's what you did. did you make sure to get the right injectors? the resistor box at least? there is a how to on doing a mpfi in the FAQ section.
ChiantiHatch
Jul 28, 2018 03:36 PM
elmerfudd
Sep 1, 2004 05:52 PM
