gsr + less then $1500 = 192whp/129tq
Old Mar 21, 2009 | 04:43 PM
sdr KEL's Avatar
Default gsr + less then $1500 = 192whp/129tq
kellybuilt project.
blox type b's + blox spring + cam gears - $550
blox fpr - $30
skunk2 pro series manifold - $150
pro fab headers - $400
3" cai w/ blox stack n filter - $50
got my buddys bone stock gsr n did a little project how much we could put down with less then 1500 spend.. and we finally got it down...
untouch block w/ the list above
192whp/129tq corrected
thanks to RNR BUILT for last min installation on the valve spring n the man himself DNR performance for the tune.
Old Mar 21, 2009 | 04:47 PM
UncleD's Avatar
Default Re: gsr + less then $1500 = 192whp/129tq
Wheres the graph?
Old Mar 21, 2009 | 04:50 PM
American.Graffiti's Avatar
Originally Posted by clean rice
Wheres the graph?
I also would like to see the graph. Any what kind of exhaust are you running? (Diameter)
Old Mar 21, 2009 | 06:23 PM
DC_Legacy's Avatar
Originally Posted by sdr KEL
kellybuilt project.
blox type b's + blox spring + cam gears - $500
blox fpr - $30
pro fab headers - $350
+ the cost of the tune.
Old Mar 21, 2009 | 06:27 PM
fatboy1185's Avatar
Big Cat
roller dyno? dont they read high? interested in trap times
Old Mar 21, 2009 | 07:11 PM
His above total comes out to $1080. With $420 left which could have gone to labor for the guy installing it and to the tuner.
Old Mar 21, 2009 | 07:29 PM
DC_Legacy's Avatar
Ahh....My goof, should of taken a moment to tally it up.
Old Mar 21, 2009 | 07:46 PM
Combustion Contraption's Avatar
As compared to.... ?
Old Mar 21, 2009 | 08:46 PM
fatboy1185's Avatar
Big Cat
dyno dynamics
Old Mar 22, 2009 | 01:46 PM
sdr KEL's Avatar
ill have the graph posted when i get back to dnr.
tune was $140
labor was free done by me
n valve spring was install by rnr built for 20 bucks
btw. it was open headers no exhaust.
Old Mar 22, 2009 | 02:00 PM
J240sx's Avatar
good numbers, congrats!
Old Mar 22, 2009 | 07:51 PM
vangaurd's Avatar
kool... what kind of dyno?
Old Mar 22, 2009 | 08:04 PM
ruffrhyder's Avatar
tune was $140
Cost total in first post was $1080, plus $160 in this post, which totals only $1240. Why does the title of thread list $1500?
Anyways, that's pretty impressive for a low budget build. My buddies gsr also with blox b's managed 185 whp at P.E.D. in Stockton with almost the same build specs with almost the same budget
Old Mar 22, 2009 | 08:06 PM
BMo Tuning's Avatar
STAR
Nice dyno numbers.........nowwwwwwwwwwwwwwww take this bitch to the track and post up some hot trap speed numbers to see if they go along with your whp numbers
Old Mar 22, 2009 | 08:46 PM
bossm's Avatar
hey how are those blox-b cams working out
and what did you tune with and what dyno
Old Mar 23, 2009 | 10:37 PM
sdr KEL's Avatar
the thread is "less then $1500" ......
its tune on crome n the dyno is dynojet
Old Mar 24, 2009 | 03:11 PM
SiB16A's Avatar
damn nice numbers...i have some pr3 pistons and a ls crank w/ the same cams and only managed 187 127 at midnight with no cam gear adjustments...i need a retune from a different tuner!
Old Mar 24, 2009 | 06:24 PM
Well this guy didnt have an exhaust bolted up. Your exhaust might have bottled necked you.
Old Mar 24, 2009 | 06:49 PM
KuEy's Avatar
man, those are good numbers. i hope i get that high cuz i have around the same mods.
Old Mar 24, 2009 | 07:18 PM
clayfight3r's Avatar
Impressive numbers. Not a bad outcome at all for the money spent. Props! And good idea for the project too, seeing what you can get out of spending X-amount.
Old Mar 24, 2009 | 07:30 PM
lakaspeed's Avatar
numbers are pretty good similar to my friends car made same power
193hp 128 trq ej1 w/ stock gsr blox b cams comptech headers
tuned open header/chromed by dave at dnr
Old Mar 24, 2009 | 10:53 PM
99ekb18b's Avatar
are the blox type b cams similar to tuner skunk2 stage 1 or 2?
Old Mar 25, 2009 | 01:27 AM
SiB16A's Avatar
i was using my friends hytech replica header with no exhuast piping either. just open header.
they are similar to stage 2
Old Mar 25, 2009 | 09:33 AM
I guess you should take a trip to DNR.
Old Mar 25, 2009 | 06:48 PM
SiB16A's Avatar
sounds about right
