Wiring Component speakers to Amp?
Old Mar 21, 2009 | 03:02 PM
XViEtBoiX's Avatar
Default Wiring Component speakers to Amp?
Do I wire a 18 Gauge speaker wire from the amp to the crossover. Then the crossover to the speaker? What about the factory speaker wire that are located on the stock speakers? Do i cut those and crimp them with the 18 gauge wires?
Im a little confused about this. Can someone show me the light??
Old Mar 21, 2009 | 03:20 PM
XViEtBoiX's Avatar
Default Re: Wiring Component speakers to Amp?
ok i got it down. Should i use 16 gauge or 18 gauge speaker wire to wire the tweeters/speakers?
Old Mar 21, 2009 | 03:37 PM
fcm's Avatar
fcm
Old Fart
Gauge of speaker wire will depend on amps RMS output, but you should be fine with 16ga.
It should be run from the amp to the passive x-overs, then to speakers, the OEM speaker wire should not be used.94
Old Mar 21, 2009 | 04:05 PM
XViEtBoiX's Avatar
Thank You.
gunsnbam
Audio / Security / Video
Feb 14, 2010 08:15 AM
jaebekae
Jan 11, 2010 12:59 PM
imadigitalgod
Jan 5, 2009 08:13 AM
phayzeone
Dec 27, 2006 07:51 PM
Gman8941
11
Oct 10, 2004 08:13 AM
