Integra max at 15 degrees timing
Old Mar 21, 2009 | 08:35 AM
mykey06's Avatar
Default Integra max at 15 degrees timing
Hi Everyone,
I have a 98 gsr with stage 1 skunk2 cams. Recently had timing belt replacement by dealer. Now i notice that i am at 15 degrees advance timing with the distributor all the way (maxed out). Is this normal, cause i think i should still be able to adjust to 16-17 right. Are there any special instructions installing the timing belt with this cams? at top dead center, everything is lined up correctly, doesn't seem like it off a tooth or something.
Thanks!!!
Old Mar 21, 2009 | 01:54 PM
babiboidb1's Avatar
Default Re: Integra max at 15 degrees timing
yeah i dont think that is right cause my DB is at 15 degrees and the dizzy isnt even advanced all the way. Have a shop check it, sometimes they'll just check it for free SOMETIMES
Old Mar 21, 2009 | 07:42 PM
NuMMbNuTtS's Avatar
Take it back to the dealer, camshaft/s are probably off a tooth.
Old Mar 22, 2009 | 06:35 AM
mykey06's Avatar
took it back to dealer and everything was right. I even opened it up again when i got home and seems like everything is right as well. the cam marking lines up with the hole (cover) and the cam gears are aligned as well. here are some pics i took.
Old Mar 22, 2009 | 06:39 AM
Dogginator's Avatar
Daisy... Daisy...
What crank pulley line did they use for TDC: the white or the red? The white line is correct. The cams can be aligned up top, but the crank can still be off by 16 degrees.
Old Mar 22, 2009 | 08:51 AM
mykey06's Avatar
it's lined up at white. the images are lined up at white. not sure if the skunk2 stage 1 cams matter.
Old Mar 22, 2009 | 09:03 AM
Dogginator's Avatar
Daisy... Daisy...
I usually take a string across the face of the cam gears to verify that all four marks are aligned.
Old Mar 22, 2009 | 11:04 AM
mykey06's Avatar
do they have to be in exact straight line?
Old Mar 22, 2009 | 12:03 PM
tlchkc's Avatar
Yes, the straighter the better!
Old Mar 22, 2009 | 12:06 PM
Dogginator's Avatar
Daisy... Daisy...
Yes. Do you have a picture with the string?
Old Mar 22, 2009 | 06:39 PM
mykey06's Avatar
unfortunately not. I will have it when i open it up again this week. its not exactly perfect but at TDC like i said, everything seems to be where they are.
Old Mar 22, 2009 | 07:25 PM
redflaredcrx90's Avatar
id say take it back . timming isnt that hard what dealership did you take it too. from those pics you timmming is way off. get a timming light and check it for you self.
Old Mar 22, 2009 | 10:33 PM
jdmef9gsr's Avatar
did you check the timing with the service light connector jumped?
Old Mar 22, 2009 | 10:39 PM
Ldo's Avatar
Ldo
Did you jump the service connector when taking your reading?
Aa.. looks like someone already beat me to that.
Old Mar 22, 2009 | 11:39 PM
racebum's Avatar
this makes a huge difference. you can only time that car right at ....what is it? 800rpm, the service jump holds it there. the exact rpm is on your sticker but above or below it will not be accurate. this is my guess as i've fired a motor that's 1 tooth off. you can't get near 15 degrees without cutting up the dizzy. my guess is the rpm was not where it should have been and thus creating the wild readings. i always always use a scan tool when i time my car to verify rpm and ecu igniton advance.
Old Mar 23, 2009 | 11:22 AM
mykey06's Avatar
Timed it right... with the jumper at normal operating temp. It's at about 800 rpm. The timing is steady at 15 degrees at max adjusted on the dizzy.
Old Mar 26, 2009 | 01:36 AM
racebum's Avatar
you can do one of two things.
A: redneck it and grind out the dizzy to get another couple degrees of timing
B: degree the cams and realize that they could be ground off a degree or two thus requiring adjustable cam gears. just incase this doesn't click for anyone reading it, if the cam is a degree or two off which is almost nothing by the eye, the dizzy will not be able to go where it should. by degreeing you verify if the dizzy slot is ground off or if the lobes are. basically you make sure the lobes are doing what they should, then do what you have to in order to set the dizzy.
Old Mar 26, 2009 | 09:16 PM
mykey06's Avatar
Thanks... i will look into that this weekend
Old Mar 27, 2009 | 05:08 AM
ok take crank pulley off them take timming cover off. line crank up with arrow up with arrow on oil pump. roll cam gears around till the both cam gears say up and the lines on the cam gears are flush with the head. put belt back on with with proper tension. turn crank pulley clock wise and check tension . re iinstall crank pulley and timing cover. and then check dizzy timing
Jap_Spec_Imports
Dec 20, 2007 06:15 PM
efyou
Jul 1, 2006 10:07 AM
impr323
Oct 9, 2005 05:33 PM
trellix78
Jan 19, 2005 09:01 PM
Kwuaymaikrup
15
Mar 8, 2004 06:43 PM
