Jumpy speedometer, but the speed sensor has been changed.
Old Mar 21, 2009 | 08:23 AM
Bad_dude's Avatar
Icon6 Jumpy speedometer, but the speed sensor has been changed.
Hello guys,
I have a 1990 Honda Accord LX AT4. About 6 months ago, the speedometer and odometer stopped working and the sport S light was blinking fast with the check engine light on. I brought it to a mechanic specialize in transmission and he replaced with Honda original parts for $135 plus $30 labor. I picked the part up myself b/c he got me a discount for $135 instead of $165. That problem is fixed and everything is fine since. But about 2 months now, my speedometer has been jumpy. I would be going like 65MPH and reaching 70 and it would stay at 65MPH then all of sudden jump to 70MPH. I know it was suppose to be at 70 b/c the RMP reading would be 3000 when it reaches about 70MPH. As I slow down it would stick at 70MPH and drop all of a sudden below that 70 reading. This usually occurs at 65-70 and around 40-45MPH. I noticed that it occurs more when the weather is colder than normal and I live in southern California and it does not get that cold at all.
Please don't tell me that it's the speed sensor again. I thought buying a Honda OEM would last longer. Please give me any idea to see if it's something else.
Thanks.
Old Mar 21, 2009 | 08:25 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Jumpy speedometer, but the speed sensor has been changed.
Cluster if you don't have a CEL most likely. Do a search.
Old Mar 21, 2009 | 09:07 AM
Bad_dude's Avatar
Do you think I should change out the circuit board?
Thanks.
Old Mar 21, 2009 | 06:27 PM
stereo69's Avatar
if the S light isn't flashing and no CEL my guess is the speedo itself.
Old Mar 21, 2009 | 07:06 PM
AccordVT's Avatar
I did a poor job of rewiring my VSS when I sheared the harness a few years back and it casused the same issue. Check all the wiring and connections. If it all checks out then I would replace the speedo.
Old Mar 21, 2009 | 07:12 PM
Bad_dude's Avatar
I'll do that. It's look kinda of dirty in that area too.
Old Mar 28, 2009 | 06:55 PM
Bad_dude's Avatar
Do you guys think that the speedometer needs some lubing?
Thanks.
kindness
Aug 31, 2012 11:20 AM
tt3
Jun 28, 2009 10:43 PM
kevodean
Feb 22, 2009 06:51 PM
Bad_dude
Jun 5, 2008 01:09 PM
tonezilla
Sep 25, 2003 08:53 PM
