inspecting timing belt
Old Aug 13, 2002 | 08:00 AM
PearlWhiteAccord's Avatar
Default inspecting timing belt
can i inspect it when i remove the valve cover???
Old Aug 13, 2002 | 09:01 AM
m0t0rhead's Avatar
Default Re: inspecting timing belt (PearlWhiteAccord)
What year car do you have ? You can inspect it without opening the valve cover.
Just look for cracks or broken off teeth or tearing.
Old Aug 13, 2002 | 09:40 AM
Default Re: inspecting timing belt (Escobar)
94 lx, how do i get to it????
Old Aug 13, 2002 | 10:07 AM
Larry Bastanza's Avatar
What is your mileage? Change interval is 90K if I recall for your year, 105K for newer models. Visual inspection is not foolproof. Timing belt have glass belts inside that weaken with age, a visual inspection will not show you that at all. You need to remove the belt, twist it to listen for cracking of the glass belts inside. Obviously, if you are doing that, you ARE changing it regardless.
If you see the belt by inspection and it "looks" bad, rounded teeth, etc. then it must go, but if the teeth are perfect that does not mean it is OK. I did mine at 90K and 185K in my 1991 Accord. Both belts "looked" perfect, but..... it's your motor!?
I have not done a 1994, but you do have to remove the valve cover to inspect the belt on a 1991, I have a 1998 now, and I also beleive you must remove the valve cover to see the belt.
HTH,
LarryB
Old Aug 13, 2002 | 10:16 AM
Default Re: inspecting timing belt (Larry Bastanza)
is removing valve cover easy??? just the bolts right????
Old Aug 13, 2002 | 12:41 PM
YeuEmMaiMai's Avatar
timing belt cover is seperate from valve cover
come off quite easily
Rotting Prelude
Nov 17, 2015 01:28 PM
fleabag
Aug 7, 2013 12:17 PM
misha
11
Nov 5, 2006 01:01 PM
smkngsr
Jun 30, 2002 08:53 PM
