T Bracket bolt loose?
Old Mar 21, 2009 | 07:33 AM
91EF919's Avatar
Default T Bracket bolt loose?
i have a 91 civic std with a 99 ls swap in it, and i found a bolt that fell off, and it was laying on the tranny. I look to see where it came from and i see a hole that is open so it fell of from there. I put it back in and it goes straight through, it doesn't even tighten. I wanted to know if there is suppose to be a nut on the other side of the bolt. The bolt goes through the top of the t bracket that goes through the motor. It is close the the starter. I couldn't take a pic cause u can barley see it,
Old Mar 21, 2009 | 08:58 AM
91EF919's Avatar
Default Re: T Bracket bolt loose?
ttt
Old Mar 21, 2009 | 10:04 AM
spoonfedcrx's Avatar
Sounds like either the bolt is the wrong one ie too short or the hole is stripped out.
Old Mar 21, 2009 | 05:13 PM
91EF919's Avatar
probably the hold got stripped out, how can this happened? I didn't do nothing and it just happened. I had my car done for about like 4 months.
omega329
Nov 13, 2013 04:49 PM
theidealone
Nov 27, 2010 07:45 PM
telekineticz
Aug 10, 2009 02:08 PM
wasp9166
Suspension & Brakes
Jul 16, 2009 01:12 PM
Pockets
Suspension & Brakes
Oct 3, 2007 04:29 PM
