3rd gear grinding?
try changing your tranny fluid. pour in a mixture of Honda MTF and GM Synchromesh modified. that usually does the trick for most people. if the grinding still continues, you have to replace the synchros or bearings.
Do you have the tools/skills to do this yourself? If not, LS trannies are relatively cheap. It would probably cost less to get another one that you know is in good shape than the cost of having someone rebuild yours. I would use this as an opportunity to upgrade to a gsr or b16 tranny, it's like driving a totally different car.
I rebuilt the LS trans that I have in a Civic with a B18A1 and the stupid grinding got worse. I put new syncros in, and it GOT WORSE! There is something that I am missing. I am still looking for someone that might have the trick to stopping the madness. Anyone??? ANYONE?????
this 3rd gear grinding is actuallt REALLY POPUALAR on integras, i did some research and found out ALOT and i mean ALOT of people have the same problems. EVEN ME. Your best bet is have the synchro replaced.
That might be because you don't keep the clutch held in long enough?...or possibly you start to miss and release the clutch to early?...something along those lines might be the problem...
