Omni Power TB ???
I have my all motor setup put 2gether and I'm only missing a TB. I was leaning towards the Omni Power 70mm TB any 1 have any experience with them, and mainly do they stick or get stuck All opinions will be great need to make a decision A.s.a.p. Thanks!
so are you saying that omni makes a throttle body that has a 70mm bore before the butterfly, and then tapers to a 68mm bore where it would come together on the intake manifold? or did you have it machined that way?
Buy a professional products throttle body, I have one and it works flawlessly and appears to be the same as OMNI's at a lesser cost.
Details:
https://honda-tech.com/forums/showth...dies+expensive
Details:
damn i didnt measure it but it better not be lol BUT as far as how it works ,its the nicest aftermarket throttle body ive ever seen really.Its not on yet but i have open it & slamed it no sticks way nicer then my old skunk2 & many others ive seen. i didnt know about the PP ,hell omni prolly bought a big group buy & took the sticker off & re selling them
oh well if it is 68mm thats fine at least it wont stick.
How much power do you gain when you increase the tb size from 60mm (2.38inch) to 68mm (2.68inch) while maintaining a stock collector size of 1.9 inch I.D. or (48.26mm)? is there some magical element of force that allows the extra air injested to efficiently pass through the same small collector hole for a HP increase? Or is there no correlation between the collector size and the throttle body size? meaning they dont have any symbiotic relationship?
I think it doesn't really matter what the facts are as long as people beleive that it will work they will be happy regardless of whether it does or not. Sorta like religion I reckon
Well, I was actually hoping to learn something here. I assume that if the engine is unable to expel the exhaust any more efficiently there would be a negligible gain from increasing the inlet size.
ITRacer121
Mar 4, 2005 10:54 AM
