manual transmission fluid in 2000 accord? questions...
Old Mar 20, 2009 | 06:40 PM
kingrukus's Avatar
Default manual transmission fluid in 2000 accord? questions...
I am looking and changing the MTF in my 2000 Accord 5 speed soon. How much bottles do I need? Is the process straight forward, or is there a writeup on this site that I could use.
I have tried to do searches, but there are so many threads with unrelated info when I search, that I spend a while and still cannot find related info.
Thanks
Old Mar 21, 2009 | 08:34 AM
Cannon Man's Avatar
Default Re: manual transmission fluid in 2000 accord? questions...
I believe the amount is just over 2qts to fill it back up. The easiest way Ive fill up my h trans was to pull the VSS on the tranny, near the back. Its just a 10mm bolt, unscrew and remove the entire sensor. Then with a long, maybe 3-3 1/2ft tube and funnel and slowly pour in the fluid. Then re-install the VSS and thats it
Draining is just removing the 1/4in drive bolt on the pas side of the tranny
Old Mar 22, 2009 | 05:21 AM
kingrukus's Avatar
Thanks for the tip
Old Mar 22, 2009 | 09:21 AM
TheMuffinMan's Avatar
He knows where you live!
https://honda-tech.com/search.php?searchid=961111
Old Mar 22, 2009 | 09:30 PM
Heat's Avatar
From this thread:
https://honda-tech.com/forums/honda-accord-1990-2002-2/manual-transmission-fluid-where-do-i-put-2258360/
Originally Posted by TouringAccord
it is straight forward, not hard to do. Not sure I would be putting an additive in there but...
Here is a diagram of your tranny housing.
#15 is the fill bolt, #17 is a crush washer.
#12 is the drain bolt, #16 is a crush washer.
You can access that by jacking up and supporting the car then removing the passenger side wheel. I use a hose inserted into the fill hole and attached to a small funnel to fill the tranny with fluid.
When you do a search, be sure to use quotes around the key words - in this case "manual transmission fluid". And search in the Accord forum (1990 - 2002) only.
zerovandez
Jan 29, 2010 07:57 AM
gshock
Sep 10, 2008 01:35 PM
stormshadow1
Aug 22, 2008 11:24 AM
silver_nteg
Mar 27, 2004 09:44 PM
tarheelborn
Sep 10, 2003 09:14 PM
