Anyone have a basemap for a gsr turbo on the s300?
Do you have a wideband in the car? If so, i could tune it for you via email if you can record your widebands readings for little money
Contact the vendor you bought the s300 from, they should be able to provide you with a basemap.
We provide all our hondata customer's with a s300 basemap free of charge with the purchase of their system.
There is no vendor, I bought it used. I have a wideband on the car, I was just wanted something close that way I wouldn't have to make alot of adjustments.
The car will not be going to a tuner, it's a crash test dummy car to learn on. I was looking for a decent map to start out on.
There is no base that will work great for you. I am just warning you. Start with a stock map and mod it to what you need.
I started w/a stock map, added the boost tables, and appropriate injector sizes. I know someone has a similar tune, hell it's a stock turbo gsr. I don't need the take it to the tuner yada yada yada **** either. It's a learning experience, I got the car running pretty smooth so far so I'll just stick to making my own map.
Once i get home ill send you a map. I have one that was tuned on 550cc and same size WG,turbo and exhaust. But i was runing with 9:1 compression if you still want it.
