**PICS**Put Type R Intake Manifold on with unknown hole that wasn't on the stock b16
Old Mar 20, 2009 | 04:47 PM
christian7750's Avatar
Default **PICS**Put Type R Intake Manifold on with unknown hole that wasn't on the stock b16
Circled in red is the hole that I dont know what to do with it. It idles high because it is sucking in air and when plugged the car dies. So should I just plug it and turn the idle screw to adjust for the loss in air?
Old Mar 20, 2009 | 04:53 PM
Cole89ef's Avatar
Default Re: **PICS**Put Type R Intake Manifold on with unknown hole that wasn't on the stock
Have you tried splitting your MAP vacuum to it?
Old Mar 20, 2009 | 04:55 PM
I haven't tried anything yet becuase I have no idea what it is there for, is that what you sugget I try?
Old Mar 20, 2009 | 05:00 PM
Just got the engine in today, here's a pic of it going in.
Old Mar 20, 2009 | 05:04 PM
civicracr's Avatar
that hole is for the evap purge line, the b16a manifold has it on the top.
Old Mar 20, 2009 | 05:07 PM
The B16 Definitely doesn't have that, the B16 manifold has 2 hoses that go onto it and the Type R has three.
Old Mar 20, 2009 | 05:17 PM
I circled all the holes in red coming off the stock b16 manifold which there only two and circled in yellow is where the unknown hole is on the Type R
Old Mar 20, 2009 | 05:37 PM
My idle air screw was all the way in for some reason, I unsrewed that and when I plug up the hole it idles fine, if anyone thinks that it shouldn't be plugged up let me know.
Old Mar 20, 2009 | 06:55 PM
93egSLEEPER's Avatar
tha b16a2 manifold has that on top.
Old Mar 20, 2009 | 08:22 PM
Unseen Racer's Avatar
i have NO clue.
but if it works not, then plug up the hole
Old Mar 20, 2009 | 11:59 PM
slowtegkauai's Avatar
Now howcome my B16 intake manifold dosent have a place for the IAT sensor to go? Am I supposed to drill it out or something? Its wierd. someone help me please..
Old Mar 21, 2009 | 04:39 AM
BryanM.'s Avatar
Resident Gearhead
You must be talking about a B16A2 intake manifold. The IAT sensor for the B16A2 is located on the breather hose a few inches before the throttle body. NOT on the intake manifold.
Old Mar 21, 2009 | 06:13 AM
Deetz's Avatar
Crazy Honda Guy
If i were you, i's switch the P30 B`6 manifold back on, it makes more power than the itr by 2-4hp at the wheels right up to 7600rpm.
You will lose both hp and tq with the itm manifold on that engine.
Old Mar 21, 2009 | 10:36 AM
So I should get an ITR intake manifold? I can get one for free, my friend is swaping his ITR for a skunk 2. What TB should I use? I was going to get a Pro products TB 65mm. Is that TB any good or should I look for something bigger/ better brand?
kbear
19
May 17, 2013 05:04 AM
honda305
26
Apr 29, 2012 08:11 AM
001020
Jan 25, 2005 08:16 AM
