Need Opinions! 90 Civic Si, Rear Bumper, Side Moldings, Red Pinstripe
I am in the process of doing a semi EF9 Conversion on my 1990 Civic Si. I just purchased a JDM EF9 Front End. Then I saw an ad on Craigslist for EF9 rear bumper for cheap. It ended up being an USDM 89' Si Rear bumper, so I bought it anyways. My question is, what side molding's should I get? 89 USDM or JDM ones? Will they match? I want to have the red pin stripe all the way around.
They look almost the same except the JDM ones are thinner. Since you have the JDM front and the 88-89 usdm rear you need to use JDM or 88-89 moldings to make everything flow front front to rear.
It will look fine with the JDM moldings or USDM. The differences are real subtle. Iam sure the USDM's are cheaper and you can probably find them new.
kris9
Aug 18, 2012 09:18 AM
egctreg
Feb 6, 2005 02:12 PM
