why does not radio work
Old Mar 20, 2009 | 03:02 PM
Got_EF8's Avatar
Default why does not radio work
sup guys just became a new proud owner of a 1990 si the question is why dosent the radio work any more when my homie sold it to me it use to have a working radio and hepulled it when he sold me the car now the radio doesnt i connected a new one and it turn on and then turns off then i got a tester and checked for dc power it it only marks 12v sometimes is there a relay or something some where let me know thanks
Old Mar 20, 2009 | 03:19 PM
Ldo's Avatar
Ldo
Default Re: why does not radio work
Please tell me you didn't make over 2000 posts without using a single comma or period. I want to help but I can't follow your message.
Old Mar 20, 2009 | 06:33 PM
DCRB's Avatar
check the under dash fuse, it's one of the 15 amp ones, i think it's the upper one. is the origonal radio plug on the car, or has it been chopped?
Old Mar 20, 2009 | 06:46 PM
Juice-UP's Avatar
OMG That's hilarious.
As for the Radio issue I was having the same problem. You checked the voltage already so that was going to be my suggestion. Mine ended up being my alternator over charging.
Old Mar 20, 2009 | 07:53 PM
shaggyeg6si's Avatar
Make sure that you get a proper wiring harness, and wire it correctly. On the red wire you should get 12v only when the key is in the on or acc position, the yellow wire should have 12v all the time.
Old Mar 20, 2009 | 08:33 PM
Got_EF8's Avatar
my bad guys that i dont use propper punctiation i just hate using it. As for the radio i did check the fuse, but i did notice a little black relay behind the radio is that have anything to do with it,
Old Mar 20, 2009 | 08:34 PM
Got_EF8's Avatar
oh and it dosn't have the OG radio harnes they choped that b!tch UP
Old Mar 20, 2009 | 08:45 PM
rattlecannedEF's Avatar
you and your 'homie' could fix it simply.
run 2 wires off the positive terminal into the car.
take the 12v+ constant and attach it to one.
take the 12v+ switched and put a toggle switch between that and the wire running off your battery.
then your deck has power to it when you flip the switch.
either that or find the problem by redoing the entire electrical system in your car.
misteryoso
Audio / Security / Video
Oct 18, 2009 08:58 AM
giiventofly
Honda Civic (2001 - 2005)
Jan 22, 2009 03:30 PM
b18_integra
Sep 22, 2007 02:14 PM
trthleshro
Oct 13, 2006 07:53 PM
aLbertska
Nov 1, 2005 08:23 AM
