ITR intake manifold
alright i have a b18c5 motor with these specs:
portflow ported and polished head
portflow springs and retainers
Toda racing spec B camshafts and adjustable cam gears
jdm p30 oversized pistons and a spoon head gasket which makes the compression 12.4
DTR header with an apexi n-1 exhaust
tuned with chrome in seattle to about 200 whp and 133 wtq.
my ITR intake manifold along with all the fuel parts are stock. the only exception is i have a B&M fuel pressure regulator. do any of you know where i could get my stock ITR intake manifold cut open and ported?
also should i get it re-tuned somewhere up here because of the altitude difference between seattle(where it was tuned) and ames, iowa(where i live)?
You will need to change the injectors to over 310 at least, and use the stock regulator. The B&M regulator is a MODIFIER, and will not go lower than the stock pressure. It is also CRAP from its failure rate.
warriorautotech
Dec 18, 2018 09:55 AM
nikanoras
18
Feb 17, 2010 06:31 AM
Teamdiesel
11
Feb 24, 2006 03:10 PM
