Crx Toe Out problum
I have searched for the past 30 min and found no defenit answer. and i need some help. rear tire is wearing out stupid fast. I need to fix it soon just tryen to find some sort of cost effective repair for a Pas. rear toe out problum. iv seen the camber fix woundering if i out a en even amout of washer if thge direction i beed the tire to go with that fix sort of fix it. Like i mean going 2 washers and Zero Washers.
well am guessing you dont have a camber kit..
just go to an alignemnt shop and tell them you want them to set the toe to ZERO.
that will save your tires about 90%
i had the same problem with the front tires and i have no camber kit.. i got it aligned and they set the toe to ZERO and now i see no tire wear.
98savage
Suspension & Brakes
20
Oct 25, 2008 06:31 PM
