Header Selection???
Old Mar 20, 2009 | 08:16 AM
Tyounin608's Avatar
Default Header Selection???
Now i've done my share of research, but i'm looking to see what you guys have to say.
I've got an AEBS sleeved 86mm gs-r w/cp 13.2:1's, H-beams, and stock crank - GS-R head knife edged intake runners, ferrera valves, crower springs and retainers, and buddyclub spec 3's (for now)
What would you recommend that I run for a header? Any other critical changes that I should make before I run this setup?
This is my first n/a build by the way.
Appreciate your input.
-Allan
Old Mar 20, 2009 | 08:34 AM
92cxturbo's Avatar
Default Re: Header Selection???
Just cerious what gas you plan on running, and is this a race only setup? From the looks of your setup(13:1 comp.) I would be looking into some type of drag header but then again the bc 3's defeat that purpose. It's best to match parts to preform together.
Old Mar 20, 2009 | 08:56 AM
00MRSi's Avatar
Contact a custom header designer and give him your engine componenets. SMSP, SSR, Hytech can all help you
Old Mar 20, 2009 | 12:39 PM
b19coupe's Avatar
Post Re: Header Selection???
With an 86mm bore and 13:1 compression, why in the name of all that is holy, would you run such a small set of camshafts?
SMSP, SSR, or Hytech would be the headers of choice for the discerning engine builder.
godfatheracing
K Series
Nov 11, 2012 05:24 PM
bertsb18hatch
10
Aug 24, 2009 06:52 PM
allmotor1313
Jul 25, 2008 10:16 AM
honda_ef9
Jan 23, 2007 03:27 PM
velocitytrends
15
Oct 25, 2004 05:23 AM
