Can this be done SI to S
I just purchased an SI Delsol 1993 no motor or transmission just the shell with the power steering and rear disc brakes can I pull them off the SI and put them in my S model 1993 Delsol. So far all I see that is different is the high pressure valve it doesnt have the wire on the S model can I leave it unpluged and will it still work.
Of course you can do that. It is very simple. You will also need the e-brake cable from the si though. Change the porportion valve also though.
Dublin
Jul 6, 2007 04:17 PM
