hey everyone any pic that you have 94-01 acura integra??
everyone... do u have pic 94-01 acura integra with 16 size rims 205/40/16 and 17 size rims 205/40/17... I want compare both 16 and 17 size .. lowride too... I like an 16 size for my acura integra gsr...
other one ...ecu p72 is obd2?? and ecu p75 is obd1?? am i right?? p72 is on it my gsr car... and need CONVERSION HARNESS obd1 to obd2??
one more... walbro 255 fuel pump... where i put it??...i don't know what i doing with it...
Thanks for help....
Thanks for help....
look at all the integra's on the integra pic thread..im sure there will be one with those rim sizes your talking about..and your ecu? all gsr's are p72...just make sure you get the right one..obd1 or obd2 "there are obd2a and obd2b" so make sure you get the correct conversion harness...p75 sounds like a ls ecu...if you need a conversion harness look on phearable.net...and your walbro 255 fuel pump would replace your stock fuel pump...and its underneeth your rear seats...but i suggest you dont do anything...cuz you dont know what your doing with it...might save us some headache
what number obd1 is???
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
There's a search button on the top right. Click on that and type in just keywords you want to search for. It's not that complicated. Being new is not an excuse not to search. You asked for help, you're being helped.
OBD1 P72 is longer like a rectangle.OBD2 P72's are square..What year is your car.96-01 are OBD2..P75 is LS but againg look at teh shape of it to give you a better idea.If your car is 96 up and you want to use a 94-95 ECU then yes you need a OBD2-OBD1 conversion harness.But it depends which one on the year of your car
About rims..Dude all you see on here are 15's and 16's,some 17's...So finding pics of 16's on a teg in the picture thread shoulnd't be too hard.
And the Walbro pump goes in your stock fuel pump position.Take out your rear bottom seat,unplug,unscrew,switch out,replug mount everything back..That's it
yeah, i know about rims but 16's seem like 17's and 17's seem like 16's...both seem same sizes .. i know different sizes.... that's really hard good sizes ... 16's is good for me...
Look at the picture thread. This is locked.
A P72 ECU is for a GSR B18C1. They came in OBDI, OBDIIa, and OBDIIb depending on the year. A P75 is for a B18B and it also came in OBDI, OBDIIa, and OBDIIb depending on the year.
The fuel pump mounts in the fuel tank.
