m2b4 trans, what fluid to use?
ROYAL PURPLE either 5w30 or 10w30 i got 5w in my transmission and its the best thing i ever used every grind i had went away and it shifts like butter
Yes, In the transmission ONLY use Honda MTF from the stealership. 2qts @ x 7$ each
or GM Synchromesh as someone else said. But I like the Honda stuff.
and Yes, I've tried Royal Purple, Mobil 1, and Redline in my trans.. and it likes Honda MTF the best.
my 200k tranny had a 3rd and 5th gear grind i changed clutch and used royal purple and i wont use anything else but that... it recommends on the website lol **** HONDA MTF
not really sure why people think that royal purple is so much better than the honda stuff. my motor doesn't even like Royal purple that much. It likes extended performance Mobil 1 better...
And It should be a No Brainer to use Honda MTF in the Trans.. It was made for it. durrr
damn brand ******
damn brand ******
I have used honda MTF and Redline. It seemed to run way better with the Honda MTF. Im willing to try the royal purple but its like $20000 a bottle. If it can get rid of my 3rd gear grind them im all for it.
RP in the motor as seen here everything is still polished and NO CARBON from when I had it built 5 years ago and it's been 470whp street warrior
BLock is currently awaiting new pistons from a failed 1000cc injector on dyno
NO yellowing NONE
Any 10w30 in the trans is fine for all my M2"a4,s4,f4, and even yeah b4" I have a tranny junk yard forming from power breaks, not oil failure.
My $0.02
NO yellowing NONE
My $0.02
phelpsj2
12
Nov 1, 2010 12:39 PM
NighthawkR184
Dec 7, 2001 04:28 PM
