trunk fills with water
Old Mar 19, 2009 | 08:16 PM
ivan93egreppin210's Avatar
Default trunk fills with water
every time my car is in the rain the trunk fills with water. rubber seals look fine. any idea what it could be??
Old Mar 19, 2009 | 08:20 PM
blackhbkid's Avatar
Default Re: trunk fills with water
I had a 93 civic and it had the same problem. It ended up being the rear quater was rusting out from the inside and leaking down into the trunk.
Old Mar 19, 2009 | 08:23 PM
jdmjoka's Avatar
DB squad #282
same old thing once again theres a bunch of threads about this mine does it also! check your tail light gaskets i heard thats what the cause of this problem is.
Old Mar 19, 2009 | 08:37 PM
dc2teg06's Avatar
I've heard the sunroof drain tubes can cause leaks.. If you have a sunroof that would be apllicable.
Do a search this has been covered a ton of times... I'm positive you'll find tons of info.
Old Mar 19, 2009 | 08:48 PM
8_UR_AWD's Avatar
I have a friend that had the same problem. His car was involved in a wreck before he bought it and I guess the hatch didnt seal right because one of the rear quarter panels was welded in a little off... the car seemed fine but upon further inspection by a body shop the car was tweaked...
Old Mar 19, 2009 | 08:51 PM
myguitar's Avatar
My issue was that the third brake light bolts were loose. I replaced the rubber gaskets and put some muscle in that bolt. Been fine since...
Old Mar 19, 2009 | 11:03 PM
BinMop's Avatar
had same problem, pulled out rear 1/4 panel on the pass side and the drain plug was unplugged. but it could be either side
Old Mar 20, 2009 | 04:19 AM
ALLxMOTOR EG's Avatar
Vietnamese!
x2
Old Mar 20, 2009 | 06:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Please search, this has been covered so many times.
In my case, my tail light gaskets were fine, but the water was coming in through the upper edge of the red lens on the taillight housings.
Old Mar 20, 2009 | 06:30 AM
twentyhurtz's Avatar
yea i think it was less than two weeks ago that i saw a very big thread on this topic already
Old Mar 20, 2009 | 06:54 AM
Community Builder
You should try searching for the threads from when I was diagnosing and fixing the MULTIPLE leaks I had back in late 2004/early 2005.
Old Mar 20, 2009 | 07:38 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Yup, search ^^^ this should be locked.
Old Mar 20, 2009 | 08:19 AM
nsxtasy's Avatar
H-T Order of Merit
From what I've seen, about 60 percent of the time, the cause is the taillight unit (gasket or lens), 20 percent of the time, the cause is the sunroof or hatch (seals or drain tubes), and 20 percent of the time, the cause is something else.
efcivic92
Dec 7, 2009 12:12 PM
Jhonny Ricer
Nov 28, 2006 07:49 PM
djdizzo
Jan 22, 2005 04:10 PM
98prelude98
Nov 25, 2004 04:24 PM
b e e
12
Nov 15, 2004 09:02 PM
