FS: lots of turbo stuff (lots of pics)...
Old Aug 13, 2002 | 05:51 AM
DSF's Avatar
DSF
Default FS: lots of turbo stuff (lots of pics)...
I'm returning my CRX to N/A operation, so these parts must go ...
14b
Good condition. No wastegate actuator or coolant pipes. Still needs turbine flange holes drilled out (part of studs still inside). $140 shipped.
*brand new* Race Engineering Blockgaurd
Fit's B-series engines. Newer design with more cooling holes. $90 shipped.
LS rods/pistons (1 sets of 4)
All came from operational stock engines. One set has @35kmiles. Have collected some minor surface rust from sitting, but nothing a wire brush couldn't remove (again, I'm lazy). Bearing surfaces are perfectly smooth. Will not seperate pistons for you. $60 shipped (each set of 4).
*brand new* 3 3/4" Autometer Sport-Comp Tach
Small dent in bezel. Comes with everything in box. 10,000rpm. $70 shipped.
Autometer Sport-Comp a/f meter *modified*
Bought from http://www.gadgetseller.com/gauges/modifiedproducts.htm . $70 shipped.
I can take more pics if desired, but will be a 1 day lag (parts at home, computer at work). Some parts are still on my CRX, but can be removed easily. Shipping means in the lower 48 states. I'm open to package deals and bartering to a certain extent. Also open to trades for working CRX a/c components (lines, receiver dryer, compressor; minus the condensor). I do not have a paypal account and will not get one. Payment by money order or COD, but COD charge will be additional. Feel free to ask around Honda-Tech for references for me (people know me? ) or on ebay (user: fiorentd). I check my hotmail account more often then Honda-Tech, so keep that in mind. Also, If you post or PM me AND email me, put you HT username in your email, so I know who you are.
Oh, I'm located in Baltimore, MD 21234.
[Modified by DSF, 8:14 AM 9/24/2002]
Old Aug 13, 2002 | 05:58 AM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default Re: FS: lots of turbo stuff (lots of pics)... (DSF)
sent you a pm
Old Aug 13, 2002 | 06:09 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (994door)
Your 99 uses saturated injectors. The DSMs are peak&hold, so you would need to use a resitor box. Sorry.
Old Aug 13, 2002 | 06:11 AM
quis23's Avatar
Default Re: FS: lots of turbo stuff (98coupe)
what type of flange do you have on the oil pan?
Old Aug 13, 2002 | 06:13 AM
cornbread's Avatar
Default Re: FS: lots of turbo stuff (DSF)
Where are you located? I'm interested in the intercooler
How much shipped 06606
Old Aug 13, 2002 | 06:15 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (quis23)
It's actually the lower flange cut off from a DSM oil return pipe. I just used rubber hose to connect it to the return flange on the turbo. I actually wouldn't recommend it for long term use, but it works fine to get you up and running. That way you can take your pan to be tapped/welded for -AN fittings (what I recommend and am doing on my Civic).
Old Aug 13, 2002 | 06:18 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (smokeeeLSR)
Where is 06606? If it's in the lower 48 states, then the price shipped is listed...$120.
Old Aug 13, 2002 | 06:20 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
interested in turbo timer, and boost gauge
Old Aug 13, 2002 | 06:34 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (MugenHonda)
replied to you pm
Old Aug 13, 2002 | 08:40 AM
v63000gtv6's Avatar
i need theVDO Vision series vacuum boost gauge
Used for @3 months. 30in/Hg-25psi. Top gauge in pillar pod in pic. $20 shipped. asap. give me the ok and i will send the money today.
-Sean
pbars319@aol.com
Old Aug 13, 2002 | 10:14 AM
wickedxboi's Avatar
Default Re: FS: lots of turbo stuff (v63000gtv6)
how much for the hks bov?
Old Aug 13, 2002 | 10:31 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (wickedxboi)
HKS SSQ BOV
Has surface scratches, but works great. $110 shipped.
*see above pic*
[Modified by DSF, 2:32 PM 8/13/2002]
Old Aug 13, 2002 | 01:23 PM
Tetsuwan Atomu's Avatar
do u still have the hks bov??? I am interested...but I got couple q's about it....right now I have dsm bov welded to my intake pipe..will the dsm bov flange mate to the hks bov?? I know this question is dumb..but I am looking for new bov and dont want to weld a new flange..thanx...
Old Aug 13, 2002 | 06:34 PM
Boosthead's Avatar
I'm interested in the Tial
Old Aug 13, 2002 | 07:53 PM
wickedxboi's Avatar
Default Re: FS: lots of turbo stuff (Boosthead)
i sent you a im
Old Aug 14, 2002 | 02:43 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (GEaRHeaDO_o)
I don't think they use the same flange.
Old Aug 14, 2002 | 04:31 AM
DSF's Avatar
DSF
All IMs/PMs have been repled too.
Old Aug 26, 2002 | 06:47 AM
DSF's Avatar
DSF
ttt
Old Aug 26, 2002 | 07:35 AM
MyWhiteCivic's Avatar
Free Bump!!!
Old Aug 28, 2002 | 04:06 PM
T25 civic's Avatar
Default Re: FS: lots of turbo stuff (MyWhiteCivic)
Still interested in the manifold.
Nick
Old Aug 28, 2002 | 07:34 PM
pelotudo's Avatar
Default Re: FS: lots of turbo stuff (T25 civic)
IM'd ya.
Old Aug 29, 2002 | 07:40 AM
GraphiteAccord's Avatar
are the injectors gone? this sucks i stumbled onto this so late. intercooler still there?
Old Aug 29, 2002 | 09:32 AM
DSF's Avatar
DSF
Default Re: FS: lots of turbo stuff (GraphiteAccord)
Injectors have been sold. Sorry.
Old Aug 29, 2002 | 09:39 AM
lsvtec101's Avatar
i just got a set of dsm 450cc's on thepartstrader.com for 100 bux 45k on em and high octane only has been run in them... not a bad deal scored a restiro pack for 38bux from there to..
Old Aug 31, 2002 | 09:14 AM
T25 civic's Avatar
Default Re: FS: lots of turbo stuff (aemcivic_02917)
I'm still waiting on the manifold answer. I sent you an email and an IM and still haven't heard a reply.
Nick
