JDM Civic Type R steering wheel
Old Mar 19, 2009 | 04:00 PM
VietSpeed's Avatar
Default JDM Civic Type R steering wheel
I have a 95 RHD Integra with a Civic Type R steering wheel but my horns don't work. Does anyone have pictures to anything to show me how to wire my horns back up? I've tried to search it but cannot find anything. The closest thing I found was for an EG.
Old Mar 19, 2009 | 09:43 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: JDM Civic Type R steering wheel
Well, the wiring for an EG is exactly the same for a DC.
I searched for you, took me 5 seconds
Enjoy.
https://honda-tech.com/forums/showth...highlight=horn
Old Mar 22, 2009 | 11:42 PM
VietSpeed's Avatar
Enjoy.
I saw that one lol, the thing is I got a SRS steering wheel. Also I've got a 95 dc2. When I took off my airbag the yellow plug with the horn wire attached is not attached to anything and when I follow it through the clock spring at the other end its also not connected to anything. Where do I connect the Yellow plug that is underneath the steering wheel?
Old Mar 23, 2009 | 01:06 AM
coolworld's Avatar
Banned
may be wiring of horn is no plug ed properly.go to repairing shop they will solve out your problem.
Old Mar 23, 2009 | 05:35 AM
VTEC_PRODUCTION's Avatar
i think the point of asking how to do it on here is to eliminate having to go to a shop and do it himself.
what garbage advice...
There should be wires for the airbag and wires inside the stock wheel for the horn. you need to use some ingenuity to connect those wires together and make your horn work.
Old Mar 23, 2009 | 01:04 PM
VietSpeed's Avatar
Technically the wiring for the horns is plugged in but on the other end of it it is not plugged into anything. When the ribbon runs through the clock spring and out under the steering column, the yellow ribbon plug is just hanging there.
Old Mar 27, 2009 | 11:06 AM
VietSpeed's Avatar
Ok, so I've got another problem... I took my cluster and the knee booster panel or whatever its called off and found out that I don't even have a SRS harness in the car. Now I'm wondering, does anyone know what pin out is what on the 95 Integra SRS ribbon from the clock spring?
Old Mar 27, 2009 | 11:57 AM
CeReal's Avatar
im so effing confused already. when i swaped a jdm srs itr steering wheel into my dc, the yellow is obviously airbag and the horn was its own wiring. it was only 2 wires, one power and one ground.
oh and a ek wheel does not fit a dc. trust me. the eg and dc are swappable.
Old Mar 28, 2009 | 01:07 PM
VietSpeed's Avatar
Well, I need help not you telling me how "effing confused" you are. Yes, I know the horn has it's own wiring and Yes, I know yellow is obviously the airbag plug. So thanks for telling me something useless. And yes an ek wheel does fit a dc wheel. and an eg setup is like the dc setup. My question to you guys is do you guys know the pin out for the yellow plug on the clock spring reel that connects to the Main SRS harness.
What I'm trying to do is to find the wire for the horn and connect a power source to it so once I push the horns it will work. The reason it is not working right now is because the clock spring reel plug that connects to the Main SRS harness is not connected to anything because I have no SRS harness at all.
Old Nov 6, 2010 | 01:16 AM
truchito86's Avatar
from what i remember when i took of my stock srs unit and wheel off for my non-srs type-R wheel, there is a socket underneath the steering column where that ribbon plugs into. It's hard as **** getting it off because there's a clip there to prevent you from taking it off (i had to break mine off) but the socket is right next to that clip. As far as the horn working, you might have to check your wire and ground and if they're okay then it should be plug and play from there.
p3t3rxp4n
Dec 13, 2013 07:31 PM
DanielHL-DK
Apr 7, 2011 11:14 AM
SiRTifiedacc
Jun 30, 2005 03:33 PM
neutron91
May 15, 2005 07:53 AM
