What do i need to complete swap? help!!
ok so i am almost done with my 2000 jdm b18c type r swap into my ej2. i had to learn alot when doing this swap. its all good though. i have to learn someway though. my question to anyone who can help me is " what do i need to finish my auto to manual conversion. The new motor is manual and the old motor was auto. i bought the pedals and a stainless steel clutch line. my dumb a$$ thought that was all i needed. now i know i need to buy a clutch resevoir but what else. what connects to the clutch pedal itself? and the clutch line is only like a 4inch line. im assuming it connects to my slave cylinder because there was one on the new motor already. but after that there is a line connected to that but its cut off. what line is that? it connects to the slave cylinder i think, according to the pictures i have seen of what the slave cylinder is. please help me identify this so i can get this clutch pedal in and get my car on the streets. i cant wait. please help. thanks.
http://www.hondacivicforum.com/forum...ad.php?t=31774
This should help you with your clutch issue. If you scroll down, it will show you the wires you need to cut and splice to add your clutch switch. Good luck.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
Here's another one that details which mounts you'll need and why.
Andy Buttowski
Oct 16, 2012 06:02 PM
SDx1990
May 12, 2010 09:45 AM
