Problem: What clutch cable for JDM B16A in 88 CRX Si?
Old Mar 19, 2009 | 12:59 PM
ADAMnQuickRDX's Avatar
Default Problem: What clutch cable for JDM B16A in 88 CRX Si?
My JDM B16A into my 88 CRX Si install is 99.9% done, last issue is getting the clutch working right. I'm using the stock 88 CRX Si clutch cable and I ordered a 90 integra clutch cable stay (bolts to the trans and you run the cable through to adjust).... but the cable seems to be too short and is not allowing any adjustment and wont let me get the trans into gear....I'm thinking if I bend the bracket down it may work but I dont wanna do that....Does anyone know what cable I need? The instructions I have say that the stock one should work but it's not. Or is it the bracket that's wrong?
Thanks!
-Adam
Old Mar 20, 2009 | 07:19 AM
Default Re: Problem: What clutch cable for JDM B16A in 88 CRX Si?
anyone?
Old Mar 21, 2009 | 08:08 AM
fck!!! $80?! ordered. =(
Old Mar 22, 2009 | 08:44 AM
91crxlsvtec's Avatar
dude just use the one for the 90-91 integra you should be fine after that.
Old Mar 22, 2009 | 11:39 AM
Lord Helmet's Avatar
any 90-93 da cable clutch should work fine. ever thought about picking it up at the local junk yard instead? alot cheaper you know.
ryanevansoh
Mar 23, 2009 02:02 PM
jakscivic
Sep 16, 2006 01:05 AM
g2tegsown
Aug 26, 2005 01:29 PM
5litereater
Jun 14, 2004 01:55 PM
juicy.koreans.suck
Mar 7, 2002 05:21 PM
