belt set up?
alright, i put a jdm h22a engine into my prelude si (h23a1). the jdm engine came with an alternator and power steering pump, i counldn't use the jdm ps pump so i just put on the h23 pump and bracket( with slight modifacation) i also put my a/c compressor and bracket onto the h22a block, all the info i gathered from here led me to believe that almost everything was a direct bolt up from block to block, this proved to be wrong with the exhaust downpipe and apparently the a/c compressor. my issue today is, i dont' have the funds to go out to honda and buy a a/c compressor pulley wheel with 5 ridges (mine has 4) as of right now i don't even plan on using the a/c, but can i get a belt that leaves the a/c compressor out, or is the alternator in another location?
basically, what belt can i put on to bypass my a/c compressor till i can buy a pully wheel for it?
bulldogpc
Apr 11, 2009 12:49 AM
reydio
Sep 26, 2006 10:06 AM
