B16A swap, VTEC hits at 5300rpm
Old Mar 19, 2009 | 12:21 PM
Rok_Stok's Avatar
Default B16A swap, VTEC hits at 5300rpm
I have a 94 Civic Si and just put in a B16A SiR-II swap and VTEC hits at 5300rpm, isn't it supposed to hit at 6000?
Is my tach off?
My knock sensor wire isn't wired correctly so I have a code 23 (knock sensor code) could this affect operation of the engine? Like a limp/safe mode?
Old Mar 19, 2009 | 12:36 PM
JohnnyWash1's Avatar
Default Re: B16A swap, VTEC hits at 5300rpm
Which ECU are you using? Also, limp mode would limit revs to 3000.
Old Mar 19, 2009 | 12:48 PM
T3KNiQe's Avatar
It all depends on what ecu your using. I think as far as stock ecu's are concerned vtec engages anywhere from 5200-6000rpm. And get that knock sensor wired correctly.
Old Mar 19, 2009 | 12:58 PM
forcefedferio's Avatar
i've seen tachs alot more off than that, my buddy i went to school with had a b16 in his ej1 and his vtec would hit at "3500 rpm" haha. It seems normal for 5300rpm, and deffinetely wire up that knock sensor!
Old Mar 19, 2009 | 01:05 PM
turboteg90's Avatar
pm for noodz
i hit vtec at 5.2k with a jdm p30 and redline at 9k.
Old Mar 19, 2009 | 01:18 PM
BryanM.'s Avatar
Resident Gearhead
92-95 rpm gauges are notorious for being innacurate.
Old Mar 19, 2009 | 01:23 PM
tegboy 195's Avatar
my b16a2, vtec comes in at 5500 or there abouts and all my buddies b16a2 about rite about the same. i wouldn't worry about it if everything sounds and felt alrite. are you planning on getting it mapped?
Old Mar 19, 2009 | 09:16 PM
Rok_Stok's Avatar
Okay, I drove the car again and now it's consistently hitting VTEC at 5500rpm.
Old Mar 19, 2009 | 09:21 PM
jayeghatch's Avatar
i hit vtec at 5300 wit p30 chip wit chrome in my b16a
Old Mar 19, 2009 | 10:36 PM
Rok_Stok's Avatar
Oh yeah, I'm using the stock JDM P30 that came with it.
As far as the tachometer being off I guess I'll have to see what RPM I'm at when I hit 60mph in 2nd gear The calculator says that with my 195/50/15 tires I should hit 60mph at exactly 8233rpm in 2nd gear, but I also have to consider that speedometers aren't always accurate either. I hit 60mph today and I think I was around 7900-8000rpm, so it can't be too far off I guess.
Old Mar 20, 2009 | 08:56 PM
Rok_Stok's Avatar
VTEC hits at 5500rpm on a P30 so my tach is right where it should be. Sweet. Nuff said.
Old Mar 20, 2009 | 10:11 PM
SiR18EG's Avatar
I'm just trying to figure out what your VTEC hits?????? Does it hit you, your passanger, or does it kind of knock on the firewall?
Old Mar 21, 2009 | 03:27 PM
Rok_Stok's Avatar
bahahaha! Nice.
But now I think the tach is off because although VTEC activates at 5500rpm, the rev limiter is at 7800 and that's not right. So when I'm at 7800, I'm really at like 8500?
Old Mar 21, 2009 | 05:36 PM
hondaholic13's Avatar
Stock P30 Vtec should be 5800RPM, my P30 is chipped to engage at 5300. I'm pretty sure stock rev limiter was @ 8200, but I could be wrong about that one.
Old Mar 21, 2009 | 09:01 PM
Rok_Stok's Avatar
I've been comparing EG6 and EH3 guage clusters and the position of the numbers on the tachometer are different. They're about 500rpm off from one another.
Oh yeah, I wired the knock sensor and have had no CEL at all, so that's good
Old Mar 23, 2009 | 06:40 PM
Rok_Stok's Avatar
Will buying an EG6 guage cluster fix my tach problem? It makes sense that it would.
Old Mar 24, 2009 | 06:08 PM
Rok_Stok's Avatar
VTEC is at "5500" and I shift at "7500" right before I hit the rev limiter. So it gets progressively worse the higher I rev. I'm already 300rpm off at VTEC, then around 700rpm off at redline. Sweet.
Old Mar 25, 2009 | 07:51 AM
superbean's Avatar
tach could be right, and maybe you low on oil? Just a thought.
Old Mar 26, 2009 | 01:22 PM
Rok_Stok's Avatar
No, oil is right on the dot. But what's weird is that now I can shift to 8000rpm and the limiter is just past that now, instead of the 7800k like before. Is there a chance my tach is learning this new engine? It seems to be!
Old Mar 26, 2009 | 03:18 PM
BryanM.'s Avatar
Resident Gearhead
It's most likely not very accurate like a lot of 92-95 tachometers tend to be, especially at high rpm.
Old Mar 26, 2009 | 03:28 PM
jdm602's Avatar
sounds like your tachs off. vtec at 5500 sounds about right. i know stock si's engauge at 5500. my 00 si did. my jdm p30 engauged at 6k if i remember right. if you get a chipped p28 you dont need a knock sensor. thats what im running right now in my gsr hatchy.
Old Mar 26, 2009 | 03:50 PM
NightCat's Avatar
VTEC should hit at 5500 last I knew, or atleast it did in my friends CRX SiR with the same motor.
Old Mar 26, 2009 | 08:08 PM
NegativeXero's Avatar
stock VTEC settings are 5500 rpms. nothing wrong. honda tachs tend to be a few hundred off anyway.
Old Mar 26, 2009 | 10:27 PM
jdm602's Avatar
jdm p30 (b16a) redline is at 8296 vtec is at 5872.
edm p30 (b16a2) redline is 8116 vtec is at 5872 as well.
all taken from basemaps in crome. thanks to me.
Old Mar 26, 2009 | 11:08 PM
93egSLEEPER's Avatar
FYI you dont need the knock sensor it just detunes your ecu
