Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fog Light Switch
Old Mar 19, 2009 | 09:48 AM
Delano Devine's Avatar
Default Fog Light Switch
I got my fog lights all wired up n they turn on but not from tha on/off switch so im asumin (duh) that tha switch doesn't work does n e 1 else have this problem...if so did u buy a new switch and it worked out ok...tha fogs r from Password:JDM if ur wondering
p.s im not tryin to hard wire it
Old Mar 19, 2009 | 09:58 AM
01_civic's Avatar
Default Re: Fog Light Switch
if u didn't hardwire it...how did it turn on without the switch?
Old Mar 19, 2009 | 10:14 AM
hondateg91's Avatar
how exactly did you wire them up?
Old Mar 19, 2009 | 10:50 AM
i forgot wut its called my friend was using it but u ho0k it up 2 tha battery to test tha wires...n we use these direction 2 wire it http://www.handa-accessories.com/civic/05fogs.pdf
Old Mar 19, 2009 | 12:38 PM
hondateg91's Avatar
you're still confusing me but the easiest eay to wire it up is either to a switch or tap into the park lights.
Old Mar 19, 2009 | 12:59 PM
DynastyRacer22's Avatar
probably the switch is messed up and somethin inside of it is pushed in causing the foglights to come on but i left mines pushed in anyways so whenever the headlights are on the fogs come on
Old Mar 21, 2009 | 07:41 PM
jdm em2's Avatar
Mine are connected to my head lights.. because the switch tends to burn out sometimes..
93DA9
Lighting
Nov 24, 2008 09:47 PM
mugenDA9 lover
Sep 24, 2006 05:25 PM
matman4444
Sep 5, 2004 12:40 PM
str8edgexx
14
Aug 29, 2002 07:30 PM
Pengo
Mar 17, 2002 10:05 AM
