Best place to fit the O2 sensor?
Old Mar 19, 2009 | 07:12 AM
vantta's Avatar
Default Best place to fit the O2 sensor?
Hi!
i would like to know wich is the best place to fit the O2 sensor on the down pipe (2,5")
the car is a civic ej8 with b16 swap, t3/t4 .63 ar garret turbo
And the EGT probe? i supose that the best place is the closest to the turbo exhaust port
This is the down pipe
thanks in advance!
Old Mar 19, 2009 | 12:34 PM
90blackcrx's Avatar
Default Re: Best place to fit the O2 sensor?
12 inches from the turbo, I usually use Lexington Steel for my measurements, he has a 12 inch member if not bigger.
Old Mar 19, 2009 | 12:38 PM
Ls_dx's Avatar
As per the AEW wideband instructions as I can remember... it was 18"
Old Mar 19, 2009 | 02:18 PM
vantta's Avatar
the wideband is the bosh lsu 4.2, and the controller PLX devices
So... maybe 15 is between 12 and 18 hehe
where did you get those length?
thanks!!
Old Mar 19, 2009 | 04:27 PM
Ls_dx's Avatar
Do it as far away from the hot turbo and exhaust gases
Old Mar 24, 2009 | 06:37 AM
vantta's Avatar
Finally, wich is the recomended distance? just under the oil pan?
thanks!
stevevang
Aug 31, 2014 08:56 PM
hucoreyCRX
Mar 17, 2007 03:58 PM
spoon95eg
Jan 22, 2006 07:42 PM
TurboJesse
Sep 28, 2003 02:55 PM
B18c1turboedEK
Sep 12, 2003 12:12 PM
