Does anyone have the Skunk 2 struts and lowing spring??? If so open.
Well I have them and my 13"s are an good fit. Because if I hit an really hard bump it doesn't **** up anything. Well i'm whating to put 15"s on there because the handling would be better and also there are nice rims out there. But the thing is all the CRX i see with 15"s and that are also lowed they are look REALLY close to the frenders. So what i'm trying to say is does anyone have 15"s on there CRX that is lowerd, and how is it if you hit an bump???
they should be fine as long as you use the proper size 15" tires. and as long as the wheel has the proper offset
If you are properly sizing your tires there wont be much difference between a 195/70/13 and a 195/50 15 tire as they are the same diameter.
I have the skunk2 Pro-S coilover kit with 15" Honda Fit wheels and I lowered it till I had minimal gap but still decent ground clearance.
Yeah... But hey thanks. I'm goin to try it because I what my car all ready for this car show I bean planning for a year to go to... But hey thanks =D
I have a 2" drop with 16" wheels and it fits fine. Just get the correct aspect-ratio tire so you retain the OEM RPM (Revolutions Per Mile). Go to Tire Rack specs and you will find it there.
Hey thanks. I am still looking into because I really what new rims it's this I know thar I have to play around with the camber.... But thanks
BlkCivicFromTeamMNR.com
Jul 25, 2007 12:24 PM
EJ2-Fluffy
12
May 14, 2004 10:10 AM
