crankshaft pulley question
d15b7 and d16z6 timing spec = 16 degrees BTDC
d15b2 and d15b6, non-HF = 18 degrees BTDC
d15b8 = 12 degrees BTDC
Depending on which d15b you have, the difference in the designs will be roughly the difference between 13 and 14 below:
One major difference is the crankshaft pulley holding tools for the two types of pulleys (when changing the timing belt) are very different.
donvito#1
Dec 17, 2011 05:01 PM
88crxdxfastwhip
Jun 13, 2008 11:56 AM
Aquafina
May 24, 2008 05:27 PM
SOHC_Brian
12
Feb 4, 2005 04:31 AM
