got a jdm b16 in my ek. how would i run a caT conv?
Old Mar 18, 2009 | 11:56 PM
wing.jai's Avatar
Default got a jdm b16 in my ek. how would i run a caT conv?
got a jdm b16 in my ek with a straight pipe. came like that when i got the car. want to drop a cat conv. since on the sohc the cat is connected to the the headers? how would i run a cat conv on the ek? just run it like on the ek coupe and dc2? HELP pelase
Old Mar 19, 2009 | 12:01 AM
wing.jai's Avatar
Default Re: got a jdm b16 in my ek. how would i run a caT conv?
Old Mar 19, 2009 | 06:48 AM
weavertime1's Avatar
you would need it placed in the pipe after the header/exhaust manifold. Are you running the car OBD2 or are you using a jumper harness and OBD1 ecu?
Old Mar 19, 2009 | 08:48 AM
ekb16's Avatar
if u wanna be legal since ur in cali then go with a magnaflow cat which is LEGAL to have IF you get the California approved cat..the universal type is better since u can have flanges welded on to ur application...if ur gonna run obd2 then get the magnaflow cat for 99-00 SI and if ur gonna run obd1 get a cat thats for the del sol b16a3..that way if u ever need to smog or bar ur car the cat will be LEGAL to have since its for that motor
Old Mar 19, 2009 | 09:12 AM
wing.jai's Avatar
you mean run it like how it was witht he sohc? cause on the sohc for the ek the cat is connected to the header half n half. do you know what i mean? or should i just run the cat like how its like on the integra and the civic coupe.? its a obd2 running on obd1 harness.
Old Mar 19, 2009 | 09:13 AM
wing.jai's Avatar
okay thanks.
Old Mar 19, 2009 | 09:37 AM
wing.jai's Avatar
Old Mar 19, 2009 | 09:51 AM
The EX is the only civic from '96 - '00 that had the cat under the car. I would not recommend trying to fab an in the manifold cat like the DX, CX, LX, and HX models are. That would be a PITA! SO YES ADD IT IN AFTER THE MANIFOLD/HEADER LIKE THE EX MODELS!
Old Mar 19, 2009 | 10:25 AM
wing.jai's Avatar
okay thanks.
Old Mar 19, 2009 | 01:35 PM
94EG8's Avatar
Seagull Management
Stock B16A exhaust manifold (or B16A specific header) + '96 - '00 EX coupe cat + '96 - '00 EX coupe intermediate pipe + stock '96 - '00 hatchback axle back/muffler = 100% bolt on exhaust.
Old Mar 19, 2009 | 07:07 PM
uwntsum's Avatar
Go buy a universal one, bring it to a muffler shop, have them cut and weld it in with flanges so you can take if off when you need.
martiniracing
Dec 9, 2009 10:52 PM
B16Civic93
Jun 29, 2007 03:13 PM
Electron Si
15
Feb 11, 2004 02:57 PM
jdmkevin
Dec 30, 2003 08:45 PM
