Crower cam broke
Today I went to check v2v, p2v, and p2h. I got my cam gears put on the cams and went to torque them down. Exhaust side torqued fine. Went to do the intake cam and you know when you can feel its getting close. I get that feeling and then it gets super easy. At this time i think that i just stripped something out. So i grab the ratchet off of the bench and start backing out the cam bolt and the cam gear falls on the ground. I contacted crower today and I was told if i want i can send it back and they will see if they will warranty it. Here are the pics sorry they are blurry.
Im just glad i guess that it did break right now instead of at 8 grand like yours. Ill gladly pay for shipping i just dont want to have to pay for a new cam
Torque wrench was set to 33lbs 4lbs below honda spec. The exhaust cam torqued fine. I seen it happen to a few guys after i bought mine ( few years back ). Just to make sure there was nothing wrong with my head, I took my stock cam and put it in the head and torqued it in and it spun the way it should. Both cams were installed with a good amount of assymbly lube.
Skunk2 has in big letters, in there instructions, not to TQ over 22 lb.ft on there chilled cast cams. They are the same as Crower. Stock Honda cams are cast steel, I think the number is 40 lb.ft. Have not seen Crower instructions in awhile. What cam gears? I know TODA or JUN required a longer"special" bolt.
Looks like it could be installer error.
What's the code on the end of the cam? is it a nuthing suffix or a "-2" suffix? The "-2"s are newer and stronger. My Crower 3s are fine and have been for 35,000 miles.
Also if when you torqued it, you applied torque in a non-axial fashion you could have aggrivated the situation that broke it.
Good luck with the build.
Pirate
Pirate
Pirate
Pirate
I didnt start this thread to blame crower. I was excited to run these cams. On the cam it says 63423 and below that is CROWER 2. If its my error then its my problem to take care off ill just have to wait and get the money to buy a new cam.
For the most part Helms manual torque specs should be treated as "maximum" that you shouldn't use or exceed.
Certain exceptions would be rod bolts, lug nuts or flywheel bolts but most everything else if you torque to spec you'll prolly strip or break something.
[sarcastic gansta shout-out omitted for Don's sake]
