another disadpointing day at the track.....
i went to the track on sunday... and the fastest i ran was 15.9... i got a black top ZC... port and polish... valve job.. intake.. headers.. exhaust... act cluth.. and a few other goodies (60 shot NOS).. i ran this wit a reaction time of 1.3 and my check engine light was (it said O2 sensor) and my tires would not get any traction at all, and my muffler was disconnected...... well.. i didnt spray NOS at the track.. only once and it ran out.. so.. count the NOS out.. i wonder if i can break into 14's wit NOS... and better driving...??
[Modified by crxtreme27, 1:00 AM 8/13/2002]
reaction time has nothing to do wiht your timeslips,
0-60 ft is like the most important thing.
i have a crx si b16a and im running a 15.2 stock. i know that you can do better than 15.9 cuz i was able to get 15.2 in my crx hf zc with i/e/h/ecu/clutch
sounds like ur traction is the problem launch lower and get some better tires.
i recommend the new bfgoodrich drag radials because they actually pay contingency if u win any events.
Oh it doesn't? Hmm this whole time I thought it did. Next time I'm at the track I won't be in such a hurry to leave the line.
damn dude that sucks....traction shouldn't be that big of an issue w/ a zc unless you had some shitty bald *** snows or something....low 14's w/ n2o when you learn to drive
Well.. the weather was about 100+ degrees... it was hot as hell...
as for my tires.. i was running 15' proxes... i think they suck ***.... i would have done better with my 14' blackies...
as for my 60'.. i think i had a 2.4 or 2.5
Your 60ft is killing you. Also, get those codes fixed!!! You wouldn't run a 1000 meter sprint with a cast on your leg would you? Why expect your car to do it? If its an o2 code, it probably wasn't hurting your 1/4 mile time though. I could be wrong about this, but WOT doesn't use the O2 readings right??? I may be totally wrong about that, if so... sorry.
Either way, you should be at least hitting mid 15s unless it was really really really humid in addition to being hot.
Guest
Posts: n/a
if your o2 is fuct your running way to rich and slowing you down. 100+ weather is horrable. reaction doesnt mean **** unless its an official race (nhra, import shoot out etc). clock starts when you pass laser. how much does your car weigh? run on a gallon of gas. im safely in the 14's w/ my NA d15b1
Well.. for a fact I know that the reaction times did affect the E.T because this was real event... (sacramento raceway CMI Summer Nationals) they were even giving away a $500 prize for anyone who actually got a .500 reaction time.. which i think no one got.. and as for my O2 sensor.. im sure that it is out.. so i guess ill just have to get one from kragen... or i might have one laying around...
here is what my time slip reads...
Reaction: 1.362
I1: 2.475
I2: 6.830
I3: 10.371
MPH (I3): 69.727
I4: 13.394
E.T: 15.992
MPH: 86.942
One question TorteX... what set up do you have to be able to run 14's with a d15b1??
Reaction: 1.362
I1: 2.475
I2: 6.830
I3: 10.371
MPH (I3): 69.727
I4: 13.394
E.T: 15.992
MPH: 86.942
(in other words, subtract your RT from your I1 time = 1.113).
Call the track and ask. I'll bet you anything that it doesn't matter. Giving away $500 for a perfect reaction time doesn't mean it had a factor in your et.
Also, don't use a crap O2... if you want your car to run decent, go get a Honda one, even a used Honda one instead of an aftermarket one.
Anyway, looking at your slip, I can assure you that R/T didn't effect ET. Your ET was bad because your launch was bad.
[Modified by therealciviczc, 1:26 PM 8/14/2002]
xx89civicracer89xx
41
Jun 19, 2006 03:47 PM
pdiddyparsons
Oct 14, 2002 07:13 PM
