will b16A FIt?
Old Mar 18, 2009 | 09:00 PM
Fatcobra's Avatar
Default will b16A FIt?
I have a chance to get my hands on an 2000 hatch or a 93 hatch. I currently have a 94 civic sedan with a b16a. I don't have the funds to by another motor at this point. i definitely want to get into a two door. I know my motor will fit and transmission will fit in the 93. I believe it is a cable transmission and the 2000 hatch came with hydro. my question is will the transmission be compatible with the 2000 hatch? or will it not matter because i have motor and transmission?
Old Mar 18, 2009 | 09:19 PM
93egSLEEPER's Avatar
Default Re: will b16A FIt?
93 civics were hydro trannys as well from the factory.. actually all civic 92-now are hydro. that swap will fit in either car exactly as it does your car now. all the same mounts and everything. you already have the cable mounts and everything so you dont have to worry about that either. just swap it.
Old Mar 19, 2009 | 10:47 AM
Jedi_Sol's Avatar
Old Mar 19, 2009 | 10:54 AM
tdbhonda's Avatar
i thought the left front mount in a 96-00 was different than a 92-95 mount
Old Mar 19, 2009 | 10:59 AM
en00be's Avatar
why would u sell your four door
four doors are SICK with b series
ferio ftw
Old Mar 19, 2009 | 11:46 AM
dividedas1's Avatar
if by cable mounts you mean the hydro -> cable conversion then yessssh your right other then...
mhmmm
and OP:
it depends where you live, some states don't allow a motor that's older then the chassis. i have the same set up in my 93 hatch. its OBD1 but cable trans, and i have the wonderful (sarcasm) hasport conversion kit.
so the answer is yes it will work, you might need a different front left mount if you go with the 2000, along with an obd2 -> obd1 piggy back wire kit. (for the ecu to make the 00 to an obd1.)
there might be a few other things, i recommend just getting the eg hatch if you want a 2 door. there will be less complications with the swap, and it will probably cost you less in the long run.
Old Mar 19, 2009 | 12:19 PM
teamworxek9's Avatar
just get the 93 everything will just swap over. putting a b16 into a 00 will take more work. dizzy, ecu, jumper harness, mounts axles, shift linkage and harness conversion.
Old Mar 19, 2009 | 01:05 PM
forcefedferio's Avatar
x2, unless you like the newer bodystyle enough to warrant the extra work/money
Old Mar 22, 2009 | 09:13 PM
en00be's Avatar
if you sell that four door your stupid
Old Mar 22, 2009 | 09:26 PM
White civic's Avatar
you want to get a 2door,is it because,it looks better and handle better or for some other reason
JDM_WHR
May 30, 2009 08:06 AM
Eibach95Civic
Aug 16, 2003 02:28 AM
JDM Civic Hatch
Oct 5, 2002 10:01 AM
SPEED123
Aug 3, 2002 07:29 AM
