crx suspension bushings
i want to change out the suspension bushings on my crx cuz they are severely worn out. given that the car is not worth much and is my beater, i want to spend as little as possible. i prefer to replace with rubber bushings, but would contemplate poly ones if they are significantly cheaper. are poly bushings significantly harsher in ride than rubber ones? also, how much maintenance do they require in terms of lubing? what poly bushings do you guys recommend? the only ones i've found on ebay are from energy suspension. finally, what are some online venders you guys recommend for purchasing OEM and aftermarket honda parts? TIA.
OEM Parts: http://www.hondapartsdeals.com/
If you choose to go poly, do not expect them to last as long, and under no circumstance replace the Rear Trailing Arm Bushing with a poly replacement. It will bind which is not how the range of motion for the poor thing was designed.
Stea
19
Jun 13, 2019 02:20 PM
fastboy559
13
May 20, 2009 05:05 PM
Cryptopsy
Jan 30, 2003 10:38 AM
