Need Help: Need a picture of rear calipers for integra
Old Mar 18, 2009 | 07:21 PM
NsX_CrX's Avatar
Default Need Help: Need a picture of rear calipers for integra
Hello. I just put on a rear disk brake conversion on my eg and supposedly it was from a dc2 gsr. After I put it on, the rear brake line does not reach the steel line on my car. If i try to get it to fit, it bends the line almost 90 degrees. The groove that the brake line sits in faces down and i looked at another integra 00' and the groove sits side ways which allows the brake line to reach the steel line without stretching and can screw onto the brackets without any problem. I'll try to take a picture of it tomorrow. Just need to see the picture where the rear brake line screws onto the caliper. Also, are all the brake calipers from 90-01 integras the same besides the type r? I think the person gave me wrong information on what type of disk brakes they are. Thanks in advance.
Old Mar 18, 2009 | 07:23 PM
NsX_CrX's Avatar
Default Re: Need Help: Need a picture of rear calipers for integra
Also, the rear wheel bearings are making noise even though they said it was good, so how can i tell which rear trailing arms they are?
Old Mar 18, 2009 | 07:53 PM
1993-eg1's Avatar
i will get u a pic in the morning all so the 93-95 delsol si (d16z6 so u know for all the odd questons thay may ask u when u go to get parts) have dikes in the rear this may help u when looking for parts i will get the pics of a teg and a delsol
Old Mar 19, 2009 | 07:38 PM
NsX_CrX's Avatar
Anyone else? Just looked at my calipers and the number on it is 7CLP13S which is the same ones that's on my friend's car, but the groove is not in the same position.
Old Mar 19, 2009 | 10:08 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
I've installed a rear brake conversion (full rear trailing arm w/brakes from a 94 Integra onto a 94 Civic hatchback) and everything fit perfect. The brake lines, ebrake cable, everything bolted perfectly.
Might be possible that he sold you the rear brake set up from a 90-93 Integra, which I believe are different than the 94-Up Integra.
Old Mar 19, 2009 | 11:37 PM
NsX_CrX's Avatar
That's the thing, I've done 2 rear Gsr disk brake conversions on 94 eg hatches and they all bolted on fine with no problem, but this one is giving me some trouble. The brake lines don't reach and I need to know what trailing arm it is because I need to replace the trailing arm bushings and wheel bearings. I read that the 90'-01' calipers may have the same 7clp13s number but now all are 100% the same.
-Todd-
Suspension & Brakes
Sep 13, 2011 07:59 PM
immajackuup
Jun 27, 2008 07:43 AM
LSej1
Nov 10, 2007 05:30 PM
EF_ST@TUS
Apr 12, 2006 01:00 PM
team w o t .com
Jul 26, 2003 05:18 AM
