Sell: Del Sol Shell.
Asking $800 obo.
Does not come w/ motor and turbo parts, aftermarket gauges, powerconverter, moates ostrich/chipped ecu or rims (Bring your own steelies), integra seats, harness bar, harnesses. It has omni power rear LCAs, springs, shocks i'll have to check on. I believe H&R w/ koni reds though.
The paint looks very good in the pic but it's a bit decieving. It's just a quick single stage w/ a few runs I did in a hurry so it didn't look too bad if/when I took it to the track or out for fun (Never made it that far haha). Hasen't been washed in almost a year ;*( (Which is why I'm getting rid of it. Don't have time to take care of it). Those shouldn't be rock chips or anything on it, just dirty. There's a run or two and/or paint blemishes, like I said a quick job for my "was gona be track car".
Please read notes at the TOP of each picture
The door locks/handles are acting a bit weird. I think it's cause whoever put the panels/handles back on after I painted it. I can fix them if you don't want to just LMK.
Serious buyers PM me if you want to see it in person.
Bolt on left side of liscence plate is broke. Needs to be taken out and retapped or just bolt/nut or self tap screw. I only ran one screw to hold it though for a long time.
(Tag lights may be missing, not sure will have to check)
No rust from what I can see. Back bumper was cut from previous owner for exhaust. Exhaust hangs a bit lower cause there was a lip on it and I didn't feel like changing it.
Hood needs adjusted to fit right and the rubber that goes on the front of it. You don't NEED it really though. AUX lights won't bolt in because of turbo setup. You'll need to make brackets to make em fit or run none or a newer bumper w/o them. I do not have the AUX lights (Lost them a few years ago).
I should have all the interior pieces. Gauges/ECU stuff and Integra Seats don't come w/ it. I'll supply a set of stock del sol seats.
Comes w/ some aftermarket floor mats. I don't think I have the stock ones no more. They were trashed.
Plastic cover that houses the shifter/boot is broke at the rear from when someone stole ipod/headunit/avcr.
New rear window trim. 120$ from Honda.
Has a viper alarm system. For some reason it isn't working. I've troubleshot everything and came to the conclusion that the "brain" is just bad. Can leave all the stuff in there for an easier install of a new system if you would like. (No longer have the keypads. It don't have remove locks or actuators.)
Everything functions on cluster. Reads 116k on chassi.
Shot of the engine bay. No AC stuff. Should be able to bolt everything back in if you can find it at a junkyard.
Bumper was cut to make room for intercooler/piping.
Ground clearance (Low air in tires)
Good windshield. No wiper arms/blades. I should be able to find a set of arms though.
I've gota pull the motor on it. Unfortunatly I left my Cell at work tonight from being in a hurry to pick someone up from the airport :/ I'll PM you my cell and you can pick up it sometime this weekend if you would like.
cool or just keep my number and give me a call when ur ready to go thanx!!
hmmm. i may be able to. i'm buying an mr2 from a friend that was n/a and converted. so i'll have to check if it has one (which it should). If it does I can leave it in np.
Unfortunatly I have to work 7 days a week for the next few weeks so I didn't get as much spare time as I'd have liked to pull it faster. I'm trying to find the title at the moment though. PMed
Well I'm back after a buncha RL crap to take care of.
I need this car gone ASAP.
Please READ first post for information on it as not everything in the pictures come w/ it...
It's a shell w/ interior. Comes w/ omni power full coilover setup w/ rear LCAs, skunk2 shortshifter. No longer has the corner lenses unfortunatly. Does NOT have wheels on it, you need to have a set of wheels/steelies to throw on it.
Looking for $500 firm for it or i'm just going to strip what I can and store it and haul the rest away for scrap.
Also have an Ameripol Top for it, $250 obo.
Harness bar for it, $125.
D16Z6 built bottom end for turbo (complete longblock w/ tranny) ran GREAT only boosted to 3psi for a month or so. Was hottanked, honed, crank balanced, girdle milled & bottom of cylinders notched for the oversized eagle rods. JE pistons. brand new bearings. Done professionaly. Oil pan has a return fitting welded on also. PM me offer or lmk if you're interested I'll get a price on it.
Please PM me with any questions or to see it etc.
andrewq9111
Jun 26, 2016 07:40 PM
94jrscgsr
Jun 19, 2004 10:34 PM
RedRacer
Apr 15, 2002 07:20 PM
