MiniME - ticking time bomb? Or just ticks?
Old Mar 18, 2009 | 06:11 PM
kls023's Avatar
From: Your house, your mom's house, your dog's house... basically anywhere you've been! haha
Default MiniME - ticking time bomb? Or just ticks?
I have a 92' Civic four door with a D15B7 block that has a D16Y8 head on it. The guy who built it supposedly said its a high compression build because he also put in ZC pistons and timing has been advanced (not sure how much).
My question is that every time I start it up, the head ticks like the valves needs adjustment or something. When its warmed up, the ticking isn't as loud but still noticable. Is this normal with a MiniME build or should I re-adjust the valves?
Also, with a 'high compression' build, do you HAVE to use 91 octane gas? When I drive it, at higher RPMs (over 3500), there's knocks and pings. I know this isn't normal.
The car is also an AUTOmatic so I barely ever take it over 3000 revs. I want to make sure everything is running how it's supposed to first before I rev it higher.
I'm new to MiniME's so anything and everything is appreciated!
Old Mar 18, 2009 | 08:33 PM
tagperformance's Avatar
Default Re: MiniME - ticking time bomb? Or just ticks?
I would re-adjust the valve lash and maybe you need to either retard the timing by twisting the distributor clockwise and also you might run 100octane to get it to stop pinging . It sounds like you might have a 12.0:1 compression motor or higher somebody correct me if i'm wrong.
Old Mar 19, 2009 | 06:08 AM
kls023's Avatar
bump
Old Mar 19, 2009 | 06:30 AM
Kricket88's Avatar
like he said retard the timing some and always run good gas... cheap gas + advanced timing + high compression = boom! detonation...
Old Mar 19, 2009 | 08:06 AM
American.Graffiti's Avatar
This sounds like a good diagnosis.
Old Mar 19, 2009 | 11:50 PM
clubef9's Avatar
The compression ratio isn't that high. The D15b7 block with a Y8 head will net you a ~10.6:1 CR. If he used ZC pistons (P29 or PM7) you are sitting very close to 11:1. If he used a two layer headgasket, you could be as high as 11.3:1. You should retard timing a couple degrees and increase fuel pressure just a tab to stop from pinging. And yes, run the highest octane you can, 93 should be good enough. I would definitely recommend you to chip your ecu and get it tuned. Do a 5 speed swap and you'll really appreciate that build! Good start though!
Old Aug 25, 2009 | 10:22 AM
HondaSPEC99's Avatar
WHen i start up my 99 Ej8 (I have a D16y8 btw) i can hear tick, tick, tick, tick rapidly then it stops, also my motor idles high at swtart up (around 1500rpms) ... It only happens after i rev it then ticking slows... Is this valve knock? idk whats wrong, my head is completly stock, I have a Skunk2 Intake manifold with the 68mm TB with an AEM SR intake, my exhaust is a full Skunk2 cat back with a DC sport 4-2-1... I really dont want to blow the motor... HELP PLEASE!!!
B_Swapped93
Aug 2, 2015 12:05 PM
importfan2
19
Oct 21, 2008 06:18 PM
outtacontrolsol
Jan 11, 2007 04:34 PM
Layziejoe775
Aug 26, 2006 03:54 PM
slowman
Aug 3, 2002 09:02 PM
