Timing Belt Changed - Check Engine Light
Old Mar 18, 2009 | 04:31 PM
benji7288's Avatar
Default Timing Belt Changed - Check Engine Light
Yesterday, i got my timing belt changed with the water pump. Today, i was driving and all of a sudden, the CEL turned on. Any ideas why? I did however, feel an increase of my car's acceleration. Maybe the timing belt is too tight? Help!
Old Mar 18, 2009 | 04:34 PM
Adam_b16a's Avatar
Default Re: Timing Belt Changed - Check Engine Light
Maybe you should check it with a code reader and see what code its throwing.
Old Mar 18, 2009 | 04:35 PM
benji7288's Avatar
Ok, you think they can do it like at Kraggen or Autozone ect.?
Old Mar 18, 2009 | 04:37 PM
Adam_b16a's Avatar
yes
Old Mar 19, 2009 | 03:48 PM
benji7288's Avatar
Ok, so i went to get it check and the code was PO420. I looked it up and it mentions that i might need a new o2 senor or a new cat. Weird that it wasn't there before I replaced my timing belt so maybe the Cat is OK. Any opinions?
Old Mar 19, 2009 | 03:51 PM
redxcobrax's Avatar
reset the ecu (disconnect the battery) then see if it comes back on, sometimes it just needs a reset.
Old Mar 19, 2009 | 03:53 PM
benji7288's Avatar
Already did that couple of times n it comes back after i drive for about 5-10 miles. Took up the ECU and it did the same
Old Mar 19, 2009 | 04:48 PM
Sr420Det's Avatar
Cat is not doing its job, you need a new one. Its just a emissions thing, dont think its killing any hp. Cant get it inspected like that though unless your in the straight boondocks
90civic-ZC
Nov 21, 2011 06:45 PM
smlipka
Honda Civic (2001 - 2005)
Jul 27, 2011 06:01 PM
pizzaauditor
Acura TL, RL & ZDX
Aug 22, 2010 07:22 PM
nexgen91
16
May 8, 2007 06:39 PM
uteric
Nov 12, 2005 10:23 AM
