4th Gen auto tranny
Old Mar 18, 2009 | 03:46 PM
Hondacivic91dx's Avatar
Default 4th Gen auto tranny
I recently purchased a 94 si. It is all stock to my knowledge. When I first got the car everything was good. But now the tranny is giving me some problems. It shifts way to soon. By the time I get to 35 mph it is in 4th gear even with the pedal to the floor. Also when going down the road and put the pedal to the floor it doesn't kick down like it used to. The cable from the throttle body to the tranny is hooked up and adjusted properly. Any suggestions to fixing this is much appreciated
Old Mar 18, 2009 | 09:09 PM
h23prelude's Avatar
Default Re: 4th Gen auto tranny
is your transmission light flashing a code, usually the "d3" or "d4" light will start blinking, check for any trouble codes first.
what color is your trans fluid? hows it smell?
does your speedometer work? the computer needs to see vehicle speed to shift properly it could be a bad speed sensor too.
possible that the internal "kick down" valve (the one attached to the throttle cable) inside the transmission is clogged/stuck, this could be checked with a transmission pressure gauge
Old Mar 19, 2009 | 04:24 AM
The d4 light flashes what does that mean though? The fluid color and level is normal
Old Mar 19, 2009 | 06:58 PM
Anyone know how to read tranny trouble codes?
Hal9000
Aug 21, 2008 09:14 PM
dthug
Jul 10, 2008 02:37 PM
ls-t del sol
Nov 29, 2004 05:11 AM
sxecustoms
Acura TL, RL & ZDX
Dec 21, 2003 07:32 PM
EL-Driver
Nov 12, 2003 12:20 AM
